Ces écouteurs sont super bien réglés et délivrent un son incroyable.
Pour moins de 70 € on a absolument rien à lui reprocher.
With the KLEE, iBasso is offering dynamic in-ear earphones with a stainless steel body and a magnetic-lithium alloy membrane driver, a technology usually found in much more expensive earphones.
The dynamic driver fitted to KLEE earphones has a 10mm-diameter diaphragm made from a magnesium-lithium alloy. This alloy has the dual advantage of being both extremely light and highly rigid. This enables the dynamic driver to offer a very good transient response, to provide better treble extension with greater clarity and finesse, and to reduce unwanted distortion and resonance to a minimum.
To make the most of the magnesium-lithium alloy diaphragm, the KLEE incorporates a dual magnetic circuit for a total magnetic flux of 1.6T. This increased power allows for greater sensitivity, reduced distortion and improved transient response, all of which result in more accurate sound reproduction, with dynamic bass and clear midrange.
In order to refine its sound signature and control its frequency response as effectively as possible, the KLEE uses a double Helmholtz acoustic cavity to deliver furthermore punchy bass while attenuating parasitic resonances.
The body of the KLEE is made of stainless steel, adding a touch of luxury to a sober design featuring reflective surfaces.
The KLEE is supplied with a silver-plated copper cable. The cable has a litz wire structure and is made up of 7 conductors, each with a cross-section of 0.06mm². The cable termination is detachable and comes with 3.5mm and 4.4mm jack connectors.
1 | Stainless steel rear panel |
2 | Driver support |
3 | Magnetic circuits |
4 | CCAW voice coil |
5 | Magnesium-lithium alloy diaphragm |
6 | 0.78mm CIEM connector |
7 | Stainless steel housing |
8 | Acoustic nozzle |
Product type | In-ear monitors |
Driver type | Dynamic |
Diaphragm | Ø10mm in magnesium and lithium alloy |
Housing material | Stainless steel |
Voice coil | CCAW 0.03mm |
Impedance | 22Ω |
Sensitivity | 112dB |
Frequency response | 20Hz-40kHz |
Total harmonic distortion(THD) | < 0.5% |
Earphone connectors | CIEM 0.78mm |
Cable termination | Jack 3.5mm Jack 4.4mm |
Cable conductor material | Silver-plated copper |
Color | Silver |
Package | 1x iBasso KLEE 1x CIEM 0.78mm cable 1x 3.5mm Jack connector 1x 4.4mm Jack connector 1x Carrying pouch 9x Pairs of ear tips |
Color | Silver |
Impedance (Ω) | 22 |
Efficiency / Sensitivity (dB) | 112.0 |
Wireless | No |
Cable termination | Jack 3.5mm |
Cable termination | Jack 4.4mm |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
