IKKO OBSIDIAN OH10 Hybrid In-Ear Monitor IEM Dynamic and Balanced Armature
The Ikko OH10 are hybrid in-ear monitor, incorporating both a dynamic speaker and a balanced armature speaker. Its ingenious design allows it to offer a high quality reproduction, enjoying both a beautiful sound richness and an amazing precision.
4.8 / 5
Reference : 13946
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 22-04-2025.
Ikko Obsidian OH01
Écouteurs Intra-Auriculaires IEM Hybrides Dynamique et Balanced Armature
Ikko Obsidian OH01 Écouteurs Intra-Auriculaires IEM Hybrides Dynamique et Balanced Armature
Pure Copper Cavity Structure
The hollow structure of the OH1 is made of Copper and its design, housing the two Titanium speakers, is designed to reduce distortion due to harmonic resonances. This design has an obvious impact on sound reproduction, which is softer and more natural.
Dynamic & Balanced Armature Drivers
The heart of these OH01s is of course its two drivers. Indeed, the headphones adopt a hybrid architecture, using both a Knowles 33518 balanced armature type driver for precise high and ultra high frequency reproduction, as well as a 10mm dynamic driver with titanium-plated Polymer membrane, ensuring high dynamics, impressive transient response and deep bass.
Silver Plated OFC Copper Cable
The detachable cable supplied with these Ikko OH01 IEMs is also of excellent quality, since its conductors are made of very high purity OFC Copper, with Silver plating, ensuring excellent signal conductivity and greatly facilitating the quality reproduction of the headphones. The cable has on the one hand (earphone side) 2-pin 0.78mm connectors and on the other hand a 3.5mm jack connector.
Ergonomic design
The design of the earphones is perfectly adapted for a comfortable fit for long listening sessions. The IEMs are perfectly maintained and are not at risk of falling, even when travelling.
Product typeIn-Ear Monitor (IEM)
DriversDynamic driver : 10mm Dynamic driver with titanium-plated Polymer membrane
Balanced Armature : Knowles 33518
Sensitivity106dB
Frequency response20Hz - 40kHz
Impedance18Ω
Cable length1.2m
Connectors2 pins 0.78mm
Jack 3.5mm
Cable conductors materialSilver plated 5N OFC Copper
Package1x Ikko OH10
1x Storage case
6x Pairs of silicone tips
ColorGray
ColorOther
Impedance (Ω)18
Efficiency / Sensitivity (dB)106.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
6 reviews
IKKO OH10, un IEM extrêmement fun
L'OH10 était un IEM que je souhaitais depuis un petit bout de temps, mais étant donné son "âge" il était compliqué de le trouver encore à la vente directement en France. Du coup je suis super content d'avoir pu le trouver sur ce site (qui possède d'ailleurs une sélection intéressante).
On est donc sur un IEM avec une sonorité en "V Shape" donc assez axé sur les bass mais qui restent extrêmement bien défini ailleurs également. Je possède déjà un Moondrop Dusk qui est plus "calme" en terme de sonorité et également un Ziigaat Doscinco qui fait également parti des IEM plus axé sur les basses.
Mais pour le moment je dois dire que je préfère l'OH10 comme utilisation quotidienne car il est plus "fun" à l'écoute surtout pour mon style de musique (Techno, DnB, Funk, etc.) .
Pour le packaging je passe vite en revu car cela ne m'a jamais vraiment intéressé, classique. Pour les accessoires on y retrouve également deux jeux différents d'embouts en différentes taille S/M/L et une housse de transport en cuir. Câble très standard, qui fait le boulot mais je le changerai pour quelque chose qui vrille moins.
Concernant la fabrication, il est principalement en métal avec un très joli design. Il est cependant assez lourd comparé à tout ce que j'ai pu avoir mais ce n'est absolument pas un soucis pour moi au contraire.
Niveau fit, c'est bon de mon côté par contre les nozzle sont très courts il faudra vraiment trouver les embouts adaptés à cela, surtout que cela a un impact très important sur le rendu final du son.
Perso j'opte pour des embouts en mousse mémoire de forme plutôt que du silicone.
Enfin pour le reste livraison très rapide avec un très bon suivis. Traitement de la commande très professionnel et bien détaillé chez Audiophonics. Rien à dire, je recommenderai très surement sur le site si je suis à la recherche de matériel.
This review has been posted for IKKO OBSIDIAN OH10 Hybrid In-Ear Monitor IEM Dynamic and Balanced Armature
Cyberpunk
Really great with FLAC material using foobar2000 and RetroArch upsampler, and also my own electronic music in Ableton Live, going through RME Fireface UCX II at 192kHz (98kHz in Ableton Live), the original cable, and some cheap 3.5mm to 1/4" adapter. Also very good with Moondrop Dawn 4.4mm over phone and CTU-01 cable, although I didn't get it to work in higher bitrates on my phone yet. I'm not sure, but I think I need to get some app for that. It seems like it has less bass compared to listening from the RME interface. Which seems reasonable considering that RME has an external power supply.
This is my first pair of IEMs. But I've used Behringer Truth B2030A and AKG K 271 MKII.
Having two types of drivers seems very basic, at least in modern terms, but it's part of a world of miniaturized Hi-Fi sound systems which fit into your ear.
Yes, my initial assumptions were confirmed. This is the closest thing we have to a virtual reality device like some of the devices described in novels of ... ah, help... the guy who wrote Neuromancer, yes, William Gibson.
Balanced armature - who cares what it means. It screams cyberpunk.
Fabuleux
Tout est déjà dit dans les commentaires précédent qui sont très juste par rapport au ressentit et plaisir procuré par ces petits bijoux ...
C'est un aller sans retour tous vos précédents intras (y compris très sensiblement plus onéreux ) vont vous paraitre fade et ... limite cassés ...
excellent écouteur sous tout rapport
Incroyable écouteur pour son prix , un son excellent et surtout une ergonomie au top du top.
Pour la première fois je trouve des intra qui s"adapte très bien à mon oreille avec les embouts d'origine. Vaux très bien son prix.
Petits bijoux
Ces écouteurs sont beaux, des petits cailloux d'une belle couleur gris métallisé. Ils sont lourds, un peu froids. Il peuvent faire mal aux oreilles si la forme du pavillon ne s'y prête pas bien. L'écoute est belle, nécessitant de bons embouts (très important) réalisant une isolation passive des bruits extérieurs. La scène sonore est large, très large. L'écoute est bien détaillée. Les basses puissantes et dynamiques, les aigus ne sont pas criards, les médiums bons. sans doute, faut-il un peu les roder. Le câble est de qualité basique convenable. Il vaudrait mieux prévoir un upgrade. En résumé, c'est un bon produit, très rapport qualité-prix. Il n'ont pas la finesse sonore d'un haut de gamme mais, ils sont enthousiasmants !!! PS pour le site de vente : la livraison de mon produit par Chronopost a été DÉPLORABLE. Le produit a été directement déposé dans une poste avec des horaires d'ouverture erronés et finalement un lieu de dépôt différent de celui indiqué par email.
The Ikko OH10 are hybrid in-ear monitor, incorporating both a dynamic speaker and a balanced armature speaker. Its ingenious design allows...
