IKKO OH1 Hybrid In-Ear Monitors IEM 18 Ohm
With its OH1s, Ikko offers high-end in-ear monitors at a low price. Indeed, it is a model with a hybrid design with two loudspeakers, usually reserved for products at much higher prices.
3.8 / 5
Reference : 13623
149,00 €tax incl.
124,17 € tax excl.
Ikko OH1
Ikko OH1 Hybrid In-Ear Monitors IEM 18 Ohm
Exceptional conception
This particular design allows a detailed reproduction and an incredible sound density for a magnificent immersion. This includes a Knowles 33518 loudspeaker for precise but non-aggressive high-frequency reproduction, as well as a second 10mm Polymer Titanium-plated dynamic loudspeaker that brings your music to life with surprising dynamics and deep bass.
Design
Inspired by rigorous ergonomic principles and numerous simulations and tests, Ikko has designed the final design of its OH1 IEMs to perfectly adapt to the human ear, while promoting a highly transparent reproduction and reducing distortion induced by internal harmonic resonances. Each earphone weighs only 6 grams, so the OH1s are extremely light and will be forgotten during your listening sessions. The headphone body is made of an ultra-light alloy to provide these IEMs with high strength and low weight.
Ikko OH1 review by Head-Fi
" We are highly impressed with iKKO OH1 and would definitely recommend to consider those among other neutral and balanced IEMs in this price range. "
Test des IEM Ikko OH1 par Head-Fi
Product typeIn-ear Monitors (IEM)
Impedance18 Ohm
Sensitivity106dB
Connector2 pins 0.78mm
DriverKnowles 33518 Balanded armature
Dynamic driver 10mm
Frequency reponse20Hz - 40kHz
Cable conductorsSilver Plated OFC Copper
Weight / IEM6g
ColorOther
ColorBlue
Impedance (Ω)18
Efficiency / Sensitivity (dB)106.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
4 reviews
Très liquide et analogique
Moelleux; souplesse; densité et matière pour un intra bien pensé et très confortable. A l'usage, on comprend pourquoi il est adulé dans le monde entier par les mélomanes nomades. Il préserve la musique dans toute son ampleur et sa texture et il distille de longues écoutes sans fatigue en se faisant oublier.
This review has been posted for IKKO OH1 Hybrid In-Ear Monitors IEM 18 Ohm
tellement décevants...
Essayons de trouver quelque chose de positif : la boîte est jolie, et les écouteurs également. Mais je dois avoir des petites oreilles... si bien qu'ils tiennent moyennement, mais surtout, ne coupent ABSOLUMENT pas du bruit ambiant... Moins bien que des écouteurs à 30 euros...
A quoi sert d'avoir un son parfait, s'il est pollué par absolument tout ce qu'il se passe autour ?
Peut-être que des meilleurs embouts seraient la solution, quand on voit que d'autres intras en fournissent de plein de formes et matières différents, ceux ne donnent le choix que de 3, juste 3 tailles différentes, et pour moi, aucune ne coupent du bruit ambiant, d'un appartement loft où tout le monde vaque à ses occupations. (Donc je ne parle pas de bruits de rue, de transport, etc...)
Bref... que faire de ces écouteurs, si le seul endroit où les utiliser est dans un silence totale sans bruits autour ? ... mais dans ce cas, quel intérêt d'avoir des écouteurs ?
Je suis EXTREMEMENT déçue, et suis retrounée à des écouteurs à 30 euros plus performants pour s'isoler et écouter de la musique.
Bonjour,
La fonction de bons intras n'est pas de vous isoler du bruit (il existe de très mauvais caques Bluetooth pour ça).
Bien que ce soit possible au moyen d'embouts spécifiques (bi-flange, tri -flange); mais bien de vous apporter un son de la meilleure qualité possible.
Oui certains constructeurs offrent un choix plus large en terme d'embouts mais pas dans cette gamme de prix.
Nous pensons aussi sincèrement que vous ne les enfoncez pas assez dans le conduit auditif, il me parait techniquement impossible qu'ils isolent moins que des écouteurs bouton à 30 € (y compris avec les embouts d'origine).
Écouteurs magnifiques!
Livraison très rapide en Allemagne!
Les écouteurs est magnifique. Avis en anglais parce que mon francais n'est suffice pas....
The sound is very good, elevated bass and astonishingly clear bass response for an in-ear-monitor.
Mids are recessed a bit except for low mids which are still affected by elevated bass (low mids are kind of elavated as well) but still very clear and differenciated.
Treble rolls off quite a bit, so you wont get a "bright" or "airy" sound out of them without equalizing very much, but otherwise than that, treble is magnificent thanks to the balanced armature driver.
Timbre is very clean and not overly metallic.
Soundstage is unrivaled in this price class, width is very very good for In-Ear-Monitors, depth is mediocre, not bad but not too good as well.
Over all an In-Ear-Monitor WELL above its price class, Sound like that is normally at least 2-3 times the price.
Also very good build, although the 2 pin connector isnt recessed, so it might come to cable connection issues if you are moving quite a lot. I have been running with them too and no problem, but after having them in while playing basketball, after an hour or so one 2 pin slided out of the port a bit.
Overall, if you want 300€+ Sound for half the price, BUY IT!
Excellents Intras
Ils font dorénavant partie de mon quotidien depuis quelques semaines.
Qualité de fabrication hors norme et sonorité excellente.
A ce prix laissez vous tenter !
With its OH1s, Ikko offers high-end in-ear monitors at a low price. Indeed, it is a model with a hybrid design with two loudspeakers,...
