IO AUDIO SOGNO In-Ear Monitors
New
IO AUDIO SOGNO in-ear monitors feature a 2DD+6BA configuration and a 5-way crossover. This means that each driver is responsible for a specific frequency range, for a smooth, harmonious sound.
By buying this product you get 43 loyalty points
Reference : 20571
439,00 €tax incl.
365,83 € tax excl.
IO Audio Sogno In-ear monitors IEM 2DD+6BA 12.8 Ohm 126.5dB 10Hz-30kHz
Photo of IO AUDIO SOGNO
IO Audio Sogno in-ear monitors feature a 2DD+6BA configuration and a 5-way crossover. This means that each driver is responsible for a specific frequency range, for a smooth, harmonious sound. An internal air-pressure regulation system limits auditory fatigue during long listening sessions and protects the drivers. Moreover, their 12.8 ohm impedance and 126.5dB sensitivity make them easy to drive. A detachable cable with silver-plated OFC 6N copper conductors is supplied with the IO Audio Sogno for optimum signal transmission. The cable also features 0.78mm CIEM connectors and interchangeable terminations: balanced 4.4mm jack, balanced 2.5mm jack and single-ended 3.5mm jack.
IO Audio Sogno : 2DD+6BA configuration
The IO Audio Sogno configuration incorporates no fewer than 8 drivers, 2 dynamic and 6 balanced armature, each of which handles a specific frequency band. One dynamic driver handles bass and vocals, while the other optimizes impedance for high frequencies. As for the Balanced Armature drivers, 4 of these provide the midrange timbre, while the remaining 2 handle the high frequencies. The result is a smooth, balanced sound reproduction.
2DD+6BA configuration of IO AUDIO SOGNO
IO Audio Sogno: 5-way crossover
IO Audio Sogno benefit from a physical 5-way crossover that gives priority to the acoustic structure of the IEMs. In addition, the design of the output nozzles reduces interference caused by the different drivers, for harmonious rendering and a significant reduction in distortion across all the frequency bands covered by IO Audio Sogno IEMs. In addition, the Sogno frequency response curve is optimized in relation to the average transfer function value of the human ear (HRTF), for a purer, clearer rendering of the sound as it reaches the eardrum.
5-way crossover from IO AUDIO SOGNO
IO AUDIO SOGNO stereo image
IO Audio Sogno: True stereo imaging
Sogno in-ear monitors use multi-channel midrange mirroring technology for optimum midrange separation, reduced distortion and superior stereo imaging.
IO Audio Sogno: Comfort and quality
An internal air pressure management system reduces hearing fatigue during prolonged listening sessions with IO Audio Sogno. It also preserves the individual drivers for greater durability.
IO AUDIO SOGNO's listening comfort
IO AUDIO SOGNO audiophile cable
IO Audio Sogno: An audiophile cable
Sogno in-ear monitors come with a detachable cable featuring OFC 6N and silver-plated OFC copper conductors for optimum signal transmission. CIEM 0.78mm connectors on the IEM side and interchangeable termination ensure a high level of compatibility: balanced 4.4mm jack, balanced 2.5mm jack and single-ended 3.5mm jack.
Product typeIn-ear monitors
Drivers2x Ø10mm dynamic driver + Ø6mm dynamic driver
4x Balanced Armature full-frequency driver
2x High-frequency Balanced Armature driver
Dynamic drivers diaphragm materialØ10mm: mixed-fiber dome + rubber surround
Ø6mm: PET
Crossover5-way electronic
4-way physical
THD< 0.8% (@ 1kHz, 94dB)
Sensitivity126.5dB/Vrms (@ 1kHz)
Impedance12.8 ohm +/-10% (@ 1kHz)
Frequency response10Hz-30kHz
Effective frequency response20Hz-20kHz
Detachable cable
Cable materialSilver-plated OFC copper
IEM connectorsCIEM 0.78mm
Interchangeable terminationBalanced 4.4mm jack
Balanced 2.5mm jack
Single-ended 3.5mm jack
Package1x IO Audio Sogno in-ear monitors
1x Detachable cable
1x Balanced 4.4mm jack termination
1x Balanced 2.5mm jack termination
1x Single-ended 3.5mm jack termination
15x Pair of ear tips
1x Cable storage pocket
1x Earphone storage pocket
Impedance (Ω)12.8
Efficiency / Sensitivity (dB)126.5
WirelessNo
Cable terminationJack 2.5mm
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
IO AUDIO SOGNO In-Ear Monitors IEM 2DD+6BA 12.8 Ohm 126.5dB 10Hz-30kHz
IO AUDIO SOGNO in-ear monitors feature a 2DD+6BA configuration and a 5-way crossover. This means that each driver is responsible for a specific...
