KIWI EARS x CRINACLE SINGOLO In-Ear Monitors IEM Black
Kiwi Ears offers us an 11m dynamic Liquid Crystal Polymer driver in-ear earphone, featuring the Kiwi Acoustic Resonance System (KARS). These earphones were developed in collaboration with Crinacle, renowned for its expertise in audio product reviews.
Reference : 19066
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 22-04-2025.
Kiwi Ears x Crinacle Singolo In-Ear Monitors IEM Dynamic Ø11mm 32 Ω Jack 3.5mm Black
Kiwi Ears x Crinacle Singolo In-Ear Monitors IEM Dynamic Ø11mm Jack 3.5mm : Front view
Kiwi Ears offers us an 11m dynamic Liquid Crystal Polymer driver in-ear monitors, featuring the Kiwi Acoustic Resonance System (KARS). These earphones were developed in collaboration with Crinacle, renowned for its expertise in audio product reviews.
Kiwi Ears x Crinacle Singolo : Kiwi Acoustic Resonance System (KARS)
Singolo earphones feature the KARS system, a discreet band-pass filter manipulating the airflow to the driver, regulating the low-frequency output. This innovation features a network of labyrinth tubes specifically designed to establish the most appropriate resonance point for Singolo earphones. The KARS makes possible a tight infra-bass band, which until now has been impossible in earphones with a single driver. The quality and texture of the bass is incomparable to any other tuning method used in a similar speaker format. Unlike traditional crossover networks that use multiple drivers with RC (resistor-capacitor) networks, KARS uses Helmholtz resonance to regulate its tuning. The flow of air in a dynamic driver determines the level of diaphragm response, but also requires additional calculations of flow, direction and volume. The KARS system enables this airflow to be precisely regulated, without unwanted artefacts, where RC networks tend to distort sound reproduction, especially when low-cost SMD components are used.
Kiwi Ears x Crinacle Singolo : a custom driver in liquid-crystal polymer
To showcase the KARS system, Singolo earphones feature Japanese liquid crystal polymer (LCP) diaphragm drivers. These dynamic 11mm drivers have been custom-designed for the KARS system, with unique acoustic chamber profiles at the front and rear. Liquid crystal polymer was chosen as the diaphragm material because of its tonal characteristics. Harder metal-based diaphragms tend to have a metallic tone in their timbre, while plastic-based diaphragms tend to sound dull. The LCP offers a perfect balance between the two rigidities for fast transient frequencies and natural timbre. Thanks to KARS technology, this speaker has been fine-tuned using acoustic dynamics alone, meaning that the sound you hear comes from the speaker alone.
Kiwi Ears x Crinacle Singolo : the Crinacle tonal signature
Singolo earphones are tuned to Crinacle's tonal signature. Featuring an 8 dB sub-bass band, the bass is incredibly powerful and punchy, but stops perfectly at 300 Hz. This results in neutral mids that articulate the natural sound of voices and instruments without any artificial swelling or muddy effect. The highs follow, with a clear peak at 3 kHz followed by a gradual decay.
Kiwi Ears x Crinacle Singolo : a detachable cable system
Singolo earphones feature a detachable cable system. Using 2-pin 0.78mm connectors, the cable can be swapped at any time. This allows you to personalize your listening experience, while guaranteeing a longer lifespan for your earphones.
Product typeIn-ear monitors (IEM)
Speaker drivers typeDynamic
Speaker drivers diametersØ11mm
Impedance32 Ω
Frequency response20Hz- 20kHz
Sensitivity108dBSPL/mW
IEM connectors formatCIEM 0.78mm
Cable connector formatJack 3.5mm
Package1x Kiwi Ears x Crinacle Singolo In-Ear Monitors
1x Jack 3.5mm to CIEM 0.78mm cable 1m2
6x Pairs of in-ear tips
Impedance (Ω)32
Efficiency / Sensitivity (dB)108
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
KIWI EARS x CRINACLE SINGOLO In-Ear Monitors IEM Dynamic Ø11mm 32 Ohm Jack 3.5mm Black
Kiwi Ears offers us an 11m dynamic Liquid Crystal Polymer driver in-ear earphone, featuring the Kiwi Acoustic Resonance System (KARS). These...
