KIWI EARS X HBB PUNCH In-Ear Monitors Jack 3.5mm
New
Kiwi Ears x HBB Punch in-ear monitors feature a 1DD+2BA+2EST design. This configuration delivers impactful bass, balanced mids and extended highs for a rich listening experience across the entire frequency band. Harmony between the different drivers is made possible by a passive 3-way crossover for a coherent, tonally pleasing sound.
Reference : 20679
499,00 €tax incl.
415,83 € tax excl.
Kiwi Ears X HBB Punch In-ear monitors IEM 1DD+2BA+2EST 12 Ohm 98dB 5Hz–44kHz
Photo of KIWI EARS X HBB PUNCH
Kiwi Ears x HBB Punch in-ear monitors feature a 1DD+2BA+2EST design. This configuration delivers impactful bass, balanced mids and extended highs for a rich listening experience across the entire frequency band. Harmony between the different drivers is made possible by a passive 3-way crossover for a coherent, tonally pleasing sound. As you can see, the Punch drivers live up to their name, with a frequency response curve that emphasizes bass, while delivering rich, detailed highs. Their 12-ohm impedance and 98dB sensitivity make the Kiwi Ears x HBB Punch relatively easy to drive. In addition, they come with a detachable 0.78mm CIEM cable to 3.5mm jack termination for a high level of compatibility.
Frequency response curve for KIWI EARS X HBB PUNCH
Kiwi Ears X HBB Punch: Deep bass
The Punch's Ø10mm composite dynamic driver provides an impressive 15dB bass boost for the most impactful sound. The overall sound is deep and immersive.
Kiwi Ears X HBB Punch: Balanced mids
The midrange is handled by two Balanced Armature drivers, carefully tuned by Kiwi Ears to deliver a balanced midrange with roundness and clarity.
Kiwi Ears X HBB Punch: Extended highs
Two electrostatic drivers extend the frequency response of the Punch up to 40kHz for detailed, subtle, but no less natural treble.
Product typeIn-ear monitors
Configuration1x Dynamic driver (1DD)
2x Balanced Armature drivers (2BA)
2x Electrostatic drivers (2EST)
Sensitivity98dB (±1dB) @ 1kHz
Frequency response5Hz-40kHz
Crossover3-way
Impedance12Ω
Detachable cable
Earphone connectorsCIEM 0.78mm 2 pins
Cable end connectorJack 3.5mm
Cable conductor materialCopper
Cable cross-section0.518mm² (20AWG)
Cable diameter1.45mm
Package1x Kiwi Ears X HBB Punch in-ear monitors
1x Detachable cable CIEM 0.78mm to 3.5mm jack termination
Impedance (Ω)12
Efficiency / Sensitivity (dB)98.0
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
KIWI EARS X HBB PUNCH In-Ear Monitors IEM 1DD+2BA+2EST 3.5mm Jack 12 Ohm 98dB 5Hz–44kHz
Kiwi Ears x HBB Punch in-ear monitors feature a 1DD+2BA+2EST design. This configuration delivers impactful bass, balanced mids and extended highs...
