LETSHUOER CADENZA 4 In-Ear Monitors
Letshuoer's Cadenza 4 are hybrid in-ear earphones featuring a dynamic driver with a beryllium-plated membrane and three balanced armature drivers. The design of these earphones has been entirely conceived around this specific feature, resulting in high-quality reproduction that combines rich sound with astounding precision.
Reference : 19176
249,00 €tax incl.
207,50 € tax excl.
Shipping date: 23-04-2025.
LETSHUOER Cadenza 4 In-Ear Monitors IEM Hybrid Dynamic + Balanced Armature 15 Ohm 102dB 20Hz-40kHz
LETSHUOER Cadenza 4 In-Ear Monitors IEM Hybrid Dynamic + Balanced Armature 15 Ohm 102dB 20Hz-40kHz: Front view
Letshuoer Cadenza 4 : A new-generation dynamic driver
Cadenza 4 earphones feature a brand-new dynamic driver with a 10 mm diameter beryllium-plated diaphragm. This diaphragm is characterized by its thinness and high rigidity. This considerably improves response speed, making the earphone easier to drive while reducing non-linear distortion. The result is a more natural sound and a fuller reproduction of low frequencies.
LETSHUOER Cadenza 4 In-Ear Monitors IEM Hybrid Dynamic + Balanced Armature 15 Ohm 102dB 20Hz-40kHz: earphone on its beryllium bed
Letshuoer Cadenza 4 : 3 balanced armature drivers
Cadenza 4 earphones are also equipped with 2 Sonion drivers and a Knowles balanced armature driver coupled with a surgically precise crossover filter. These additions enhance tonal density, enrich midrange detail and extend the treble frequency range. The combination of these 3 balanced armature drivers delivers a sound reproduction as delicate as it is transparent.
Letshuoer Cadenza 4 : Custom-designed acoustic tubes and crossover
Cadenza 4 earphones adopt a solution involving 3 acoustic tubes coupled to a 4-channel electronic crossover. With its cutting-edge 50μm 3D-printed acoustic tubes, Letshuoer has ensured that they are calibrated to recreate a faithful, smooth and balanced sound. The four-channel electronic crossover allows precise control of frequency distribution and considerably reduces phase errors.
LETSHUOER Cadenza 4 In-Ear Monitors IEM Hybrid Dynamic + Balanced Armature 15 Ohm 102dB 20Hz-40kHz: Acoustic tube diagram
LETSHUOER Cadenza 4 In-Ear Monitors IEM Hybrid Dynamic + Balanced Armature 15 Ohm 102dB 20Hz-40kHz: earphone in one ear
Letshuoer Cadenza 4 : A custom 3D-printed chassis
The Cadenza 4 earphones are the opportunity for a new collaboration between Letshuoer and HeyGear Technology to refine the chassis. The body of the earphones is precisely calibrated to ensure long-term wearing comfort. The front plate is made of CNC-machined aluminum alloy with a matt finish, giving a textured handfeel.
Letshuoer Cadenza 4 : Connectors as practical as they are qualitative
The earphones come with a cable made of 392 strands of pure silver-plated single-crystal copper, offering optimum conductivity combined with minimal signal loss. Furthermore, the cable comes with 3 interchangeable jack connectors (2.5mm / 3.5mm / 4.4mm) for maximum device compatibility.
Type of productIn-Ear Monitors (IEM)
Type of drivers1x Dynamic driver
3x Balanced armature drivers
Headphone connectorsCIEM 0.78mm 2 pins
Cable connectorJack 2,5mm / 3,5mm / 4,4mm
Frequency response20Hz - 40kHz
Impedance15Ω
Sensitivity102dB
Cable length1.2m
ColorSilver
Package1x Pair of Letshuoer Cadenza 4 earphones
1x 1.2m 0.78mm 2-pin CIEM cable
3x Modular jack connector
6x Pairs of ear tips
1x Storage pocket
ColorSilver
Impedance (Ω)15
Efficiency / Sensitivity (dB)102.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 2.5mm
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
LETSHUOER CADENZA 4 In-Ear Monitors IEM Hybrid Dynamic + Balanced Armature 15 Ohm 102dB 20Hz-40kHz
Letshuoer's Cadenza 4 are hybrid in-ear earphones featuring a dynamic driver with a beryllium-plated membrane and three balanced armature...
