LETSHUOER DZ4 In-Ear Monitors IEM Dynamic 12 Ohm 104dB 20Hz-40kHz
These DZ4 in-ear monitors from Letshuoer are great companions for everyday use. They feature 3 dynamic 6mm titanium drivers and a 6mm passive radiator. These earphones have a wide frequency response from 20Hz to 40kHz and a sensitivity of 104dB.
Reference : 17977
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 23-04-2025.
LETSHUOER DZ4
LETSHUOER DZ4 Écouteurs Intra-Auriculaires IEM Dynamiques 12 Ohm 104dB 20Hz-40kHz
These DZ4 in-ear monitors from Letshuoer are great companions for everyday use. They feature 3 dynamic 6mm titanium drivers and a 6mm passive radiator. These earphones have a wide frequency response from 20Hz to 40kHz and a sensitivity of 104dB. Their design provides clear, precise sound reproduction with deep bass, enhanced by the passive radiator.
Outstanding design
The DZ4s have 3 dynamic 6mm titanium drivers, each playing a role in reproducing the different frequencies of the audio source signal. They deliver excellent high-frequency and midrange performance, with excellent responsiveness and energy. But the special feature of the DZ4s is that they incorporate a 6mm passive radiator. Using the waves generated by the other transducers, this passive radiator reinforces the low frequencies.
4-way acoustic tubes & Quality connectors
Thanks to a 4-way acoustic tube and 2-way crossover, the DZ4s transmit sound in a very stable way. What's more, the loudspeakers are connected to the two input pins via a flexible printed circuit (FPC).
High-end cable
Letshuoer's DZ4s are supplied with a braided cable consisting of 4x0.05mm silver-plated copper conductors. The connectors on both sides of the cable are standard, with a Jack 3.5mm and two 0.78mm double-pin CIEM connectors.
Aesthetics & Ergonomics
The semi-open enclosure of the DZ4 is made of CNC-machined anodised aluminium with matt treatment and resin. In terms of ergonomics, the DZ4s will fit the shape of your ears perfectly for prolonged use without pain or discomfort. What's more, they come with a storage box and 6 pairs of eartips.
Product typeIn-ear monitors (IEM)
Drivers type3DD + 1RP :
3* Titanium dynamic drivers
1* Titanium passive radiator
Earphones connectorCIEM 0.78mm 2pin
Cable connectorJack 3.5mm
Frequency response20Hz - 40kHz
Impedance 12Ω
Sensitivity104dB
Cable conductors materialSilver plated copper
ColorSilver
PackageLetshuoer DZ4 IEM
1* Jack 3.5mm to CIEM 0.78mm 2pin cable
1* Storage box
6 pairs of eartips
ColorSilver
Impedance (Ω)12
Efficiency / Sensitivity (dB)104.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
These DZ4 in-ear monitors from Letshuoer are great companions for everyday use. They feature 3 dynamic 6mm titanium drivers and a 6mm passive...
