By buying this product you get 59 loyalty points
LETSHUOER EJ07M headphones are designed for professional use. It is particularly suitable for stage performances and studio mixing by meeting the high demands of the environment.
They carry two IEM hybrid drivers with advanced electrostatic technology. Indeed, four sonion EST65QB02 speakers and two sonion 2389 symmetrical armature bass-midrange speakers are present in these headphones. In addition, there is a dynamic speaker in each of them with a 10mm monocarbon membrane. It is this tribride association with 7 drivers that allows a sound transcription with very low distortion, superb highs as well as a precise and fast response. In general, the transcribed sound is rather soft and very detailed.
Whether you are a singer, DJ, musicians, audiophile, or studio professional, these headphones will suit you.
The EJ07M are housed in a sound cavity made of an aluminum alloy found in the aeronautical industry. This brings them two advantages, they block up to 26dB of ambient noise and remain comfortable over long sessions of use.
The EJ07M in-ear headphones are equipped with a high-purity OCC copper monocrystalline cable featuring a braided structure that also helps reduce noise and makes the cable strong while being lightweight and flexible. In terms of connectors, this model has standard 2 pin 0.78mm connectors and a balanced 4.4mm jack.
The LETSHUOER team, in addition to integrating a high-quality 316L stainless steel shell on the design of the EJ07M, has also affixed a front panel with a unique look with a carbon fiber faceplate and gold flakes. More generally, the ergonomic shape makes them comfortable to use.
Type of product | In-Ear Monitors (IEM) |
Type of drivers | Sonion squad EST65QB02 Sonion 2389 10mm Monocarbon Nanotube Dynamic Driver |
Headphone connectors | 0.78mm 2PIN |
Cable connector | Jack 4.4mm |
Frequency response | 20Hz - 30kHz |
Impedance | 19Ω |
Sensitivity | 107dB/mW |
DIstorsion | 0.5% |
Cable material | OCC Pure copper |
Cable length | 1.25m |
Color | Black graphite |
Package | 1x In-ear headphones (IEM) 1x Storage metal case 1x 0.78mm 2 Pin cable 1x 4.4mm balanced Jack 6x pairs of silicone ear tips (S / M / L) 3x pairs of foam ear tips (S / M / L) |
Color | Black |
Color | Gold |
Impedance (Ω) | 19 |
Efficiency / Sensitivity (dB) | 107 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 30000 |
