By buying this product you get 109 loyalty points
Letshuoer Mystic 8 in-ear monitors are top-of-the-range IEMs featuring no fewer than 8 Balanced Armature drivers (4 Sonion + 4 Knowles) for detailed, powerful and dynamic sound. This configuration allows each driver to work on a specific frequency band for a precise sound. Low frequencies are optimized by a low-pass filter module for a punchy, immersive sound. Balanced Armature drivers work in harmony thanks to a 3-way crossover and 4 acoustic tubes. The Letshuoer's low impedance of 18 ohms and high sensitivity of 107dB make them easy to drive. In addition, they feature 0.78mm CIEM connectors and a detachable audiophile cable with balanced 4.4mm jack termination for a high level of compatibility.
The Letshuoer Mystic 8 features 4 Sonion and 4 Knowles Balanced Armature drivers. Each driver works on a specific frequency range for precise, powerful and dynamic sound reproduction.
The Letshuoer Mystic 8 features a low-pass filter module that optimizes bass reproduction. The module is integrated directly into the acoustic tube for precise selection of low frequencies and attenuation of high frequencies, resulting in an impactful, immersive final sound.
Letshuoer's Mystic 8 features a 3-way crossover and 4 acoustic tubes for harmonious operation of all Balanced Armature drivers. This configuration ensures smooth, precise sound reproduction while minimizing distortion for a clear, pleasant listening experience.
To accompany the Mystic 8, Letshuoer has chosen a high-quality detachable cable. This cable is made of 8 silver-plated 20x0.05mm monocrystalline copper conductors and benefits from a layer of shielding. The cable's high-end design ensures optimum signal transmission. In addition, it features 0.78mm CIEM connectors and a balanced 4.4mm jack termination for a high level of compatibility.
Letshuoer have made something special here – a specialist IEM for those who value a clean midrange above all. I’d happily recommend getting the Mystic 8 to seasoned listeners who know what they like and what they’re getting into.
Product type | In-ear monitors |
Drivers | 4x Sonion Balanced Armature 4x Knowles Balanced Armature |
Sensitivity | 107dB |
Frequency response | 20Hz-40kHz |
Impedance | 18 ohm |
Shell material | Titanium alloy |
IEM connectors | CIEM 0.78mm |
Detachable cable | |
Cable length | 1.25m |
Conductive cable materials | Silver-plated monocrystalline copper |
Cable structure | 8x20x0.05mm |
Cable terminaison | Balanced 4.4mm jack |
Color | Black |
Package | 1x Letshuoer Mystic 8 1x CIEM 0.78mm detachable cable to 4.4mm jack termination 9x Pair of in-ear tips 1x Carrying pouch |
Color | Black |
Impedance (Ω) | 18 |
Efficiency / Sensitivity (dB) | 107 |
Wireless | No |
Cable termination | Jack 4.4mm |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
