LETSHUOER S12 Dynamic Planar-membrane In-Ear Monitor IEM 16 Ohm 102dB 20Hz-30kHz
The LETSHUOER S12 earphones have been designed to bring a unique touch to the range, offering a happy medium in terms of settings and price. Using brand new 14.8mm flat diaphragm dynamic speaker.
Reference : 17589
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 23-04-2025.
LETSHUOER S12
Dynamic Planar-membrane In-Ear Monitor IEM 16 Ohm 102dB 20Hz-30kHz LETSHUOER S12 Dynamic Planar-membrane In-Ear Monitor IEM 16 Ohm 102dB 20Hz-30kHz
LETSHUOER's S12 earphones feature a 14.8mm flat membrane that provides clarity and good resolution for the sound reproduction of your favorite songs. These headphones are good companions for everyday use. The sensitivity is 102dB and the adjustments made to the management of the treble and bass allowing the restitution of many audio details are of professional quality.
Practical and qualitative connections
There are connectors with 2 pins of 0.78mm on each earphone. Fairly standard model, the cable is therefore interchangeable. In addition, at the end of the cable you will find a 3.5mm jack that will connect to most of your mobile devices.
A detailed design
The LETSHUOER team has worked to make these headphones solid and reliable. Indeed, their shell benefits from a 5-axis CNC machining process and two ventilation holes are present to reduce the effect of pressure on the eardrums in order to protect your hearing. Note also the cable which turns out to be silver plated copper 128 strands allowing it to be solid while maintaining a certain flexibility.
Type of productIn-Ear Monitors (IEM)
Type of driversPlanar membrane
Headphone connectors
0.78mm 2PIN
Cable connectorJack 3.5mm
Frequency response20Hz - 30kHz
Impedance16Ω
Sensitivity102dB/mW
Cable length1.25m
ColorSilver
Package1x Storage pocket
1x 0.78mm 2 Pin to 3.5mm Jack cable
6x pairs of ear tips (S / M / L)
ColorSilver
Impedance (Ω)16
Efficiency / Sensitivity (dB)102.0
Lowest frequency (Hz)20
Highest frequency (Hz)30000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
The LETSHUOER S12 earphones have been designed to bring a unique touch to the range, offering a happy medium in terms of settings and price. Using...
