LETSHUOER S12 PRO Dynamic Planar-membrane In-Ear Monitor IEM 16 Ohm 102dB 20Hz-20kHz
The LETSHUOER S12 PRO earphones have been designed to bring a unique touch to the range, offering a pro quality in terms of settings. Using brand new 14.8mm planar diaphragm dynamic speaker.
Reference : 17590
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 22-04-2025.
LETSHUOER S12 PRO
Dynamic Planar-membrane In-Ear Monitor IEM 16 Ohm 102dB 20Hz-20kHz LETSHUOER S12 PRO Écouteurs Intra-Auriculaires IEM Dynamique Membrane Planaire 16 Ohm 102dB 20Hz-20kHz
LETSHUOER's S12 PRO earphones feature a 14.8mm planar membrane that provides clarity and good resolution for the sound reproduction of your favorite songs. These headphones are good companions for everyday use. The sensitivity is 102dB and the adjustments made to the tone management provide clear trebles and punchy bass as well as the reproduction of many audio details in a professional manner.
Interchangeables connectors
There are connectors with 2 pins of 0.78mm on each earphone. Fairly standard model, the cable is therefore interchangeable. In addition, at the end of the cable you will find the possibility of connecting 3 different jacks, a 2.5mm jack, a 3.5mm jack and a 4.4mm jack which will connect to the majority of your devices and allow you to take advantage of their balanced output if present (DAC, Amp, Telephone, Computer, etc).
LETSHUOER S12 Écouteurs Intra-Auriculaires IEM Dynamique Membrane Planaire 16 Ohm 102dB 20Hz-30kHz
High-RES certification
The IEM S12 PRO in-ear headphones benefit from the Hight-RES Audio certification. This means that they have a higher quality level of high fidelity audio reproduction than the current standard such as CD or mp3.
A detailled design
The LETSHUOER team has worked to make these headphones solid and reliable. Indeed, their shell benefits from a 5-axis CNC machining process and two ventilation holes are present to reduce the effect of pressure on the eardrums in order to protect your hearing. Note also the cable which turns out to be composed of 4 silver-plated copper filaments 98 strands allowing it to be solid while maintaining a certain flexibility.
Type of productIn-Ear Monitors (IEM)
Type of driversPlanar membrane
Headphone connectors
0.78mm 2PIN
Cable connectorJack 2.5mm
Jack 3.5mm
Jack 4.4mm
Impedance16Ω
Sensitivity102dB/mW
Cable length1.25m
ColorSilver
Package1x In-ear headphones (IEM)
1x Storage pocket
1x 0.78mm 2 Pin cable
1x 2.5mm Jack
1x 3.5mm Jack
1x 4.4mm Jack
6x pairs of ear tips (S / M / L)
ColorBlue
Impedance (Ω)16
Efficiency / Sensitivity (dB)102.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 2.5mm
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
Ecouteurs oui, câble non
Les écouteurs sont super (c'est du planar top niveau) mais le câble est à jeter illico... il étouffe complètement le son, j'ai pu le vérifier en le remplaçant par celui livré en standard avec mes 7Hz Timeless: c'est le jour et la nuit, l'écoute est transformée, puissante, aérée, normale quoi. C'est un peu limite de fournir un câble de piètre qualité avec ces écouteurs...
This review has been posted for LETSHUOER S12 PRO Dynamic Planar-membrane In-Ear Monitor IEM 16 Ohm 102dB 20Hz-20kHz
The LETSHUOER S12 PRO earphones have been designed to bring a unique touch to the range, offering a pro quality in terms of settings....
