MOONDROP ARIA In-Ear Monitors IEM Dynamic 10mm 122dB 32 Ohm 5Hz-36kHz
Moondrop's Aria in-ear headphones combine balance, transparency, richness and a wide sound stage. They integrate a dynamic 10mm transducer within a double magnetic cavity, with LCP (Liquid Crystal Polymer) membrane offering an excellent transient response and a detailed restitution.
Reference : 16511
79,00 €tax incl.
65,83 € tax excl.
This product has been replaced by the Moondrop Aria II model.
Moondrop Aria
Moondrop Aria Écouteurs Intra-Auriculaires IEM Dynamiques 10mm 122dB 32Ω 5Hz-36kHz
Moondrop's Aria in-ear headphones combine balance, transparency, richness and a wide sound stage. They integrate a dynamic 10mm transducer within a double magnetic cavity, with LCP (Liquid Crystal Polymer) membrane offering an excellent transient response and a detailed restitution. The ultra-thin Daikoku-CCAW coil makes the suspension system very light for a natural sound. The new waveguide significantly reduces distortion caused by high frequency phase interference. The shape of the body is designed to fit the shape of the ear perfectly, giving the Aria a clean, modern look. The body is made of precision CNC machined metal. Within it, the acoustic chamber is equipped with several tubes allowing a perfect adjustment of the frequency response. The Aria comes with a detachable cable, connecting to the headphones on a standard 2 pins 0.78mm connector.
Moondrop Aria écouteurs intra-auriculaires IEM dynamiques 10mm 122dB 32 Ohm 5Hz-36kHz
1High frequency phased waveguide
2Ø0.035mm CCAW voice coil
3Brass inner cavity
4Patented anti-clogging filter
5LCP Diaphragm
6N52 Neodymium magnet internal magnetic circuit
Product typeIn-ear monitors (IEM)
Speaker driver type10mm Dynamic LCP
MagnetNeodymium N52
Connector2 pins 0.78mm
Impedance32Ω ±15% @ 1kHz
Sensitivity122dB/Vrms @ 1kHz)
Frequency response5Hz-36kHz
PackageMoondrop Aria
Detachable cable
12x eartips
Case
Impedance (Ω)32
Efficiency / Sensitivity (dB)122.0
Lowest frequency (Hz)5
Highest frequency (Hz)36000
2 reviews
Aria
Nice, very nice
This review has been posted for MOONDROP ARIA In-Ear Monitors IEM Dynamic 10mm 122dB 32 Ohm 5Hz-36kHz
À la hauteur des TRÉS hautes attentes
Les MOONDROP ARIA sont à la hauteur des TRÈS hautes attentes que j'avais. Impossible de trouver de gros points faibles. Agréables pour écouter tout types de musiques ou regarder des films grâce à un des basses boostées et une spacialisation large.
Je pourrais seulement déplorer un cable un peu cheap mais qui fait le travail.
Dans tout les cas, les ARIA sont devenus le mètre étalon des écouteurs intra en dessous de 100€ et ne peuvent que difficilement décevoir, ce qui en fait la paire parfaite pour rentrer dans le hobby audiophile.
Moondrop's Aria in-ear headphones combine balance, transparency, richness and a wide sound stage. They integrate a dynamic 10mm transducer...
