MOONDROP BLESSING 3 In-Ear Monitor IEM
Moondrop offers with the Blessing3, evolution of the Blessing2, exceptional in-ear headphones, offering a sound reproduction as rich as it is precise. The IEMs integrate for this no less than three different double loudspeakers, each responsible for the reproduction of a defined frequency range. A particularly effective triple filter thus makes it possible to distribute these frequency bands according to each transducer.
By buying this product you get 38 loyalty points
Reference : 17694
389,00 €tax incl.
324,17 € tax excl.
Shipping date: 06-01-2026.
Moondrop Blessing3
 In-Ear Headphones IEM Triple Drivers 14.8 Ohm 120dB 10Hz - 30kHz
MOONDROP BLESSING3 Écouteurs Intra-Auriculaires IEM Triple Haut-Parleurs 14.8 Ohm 120dB 10Hz - 30kHz
Moondrop offers with the Blessing3, evolution of the Blessing2, exceptional in-ear monitors, offering a sound reproduction as rich as it is precise. The IEMs integrate for this no less than three different double drivers, each responsible for the reproduction of a defined frequency range. A particularly effective triple filter thus makes it possible to distribute these frequency bands according to each transducer.
2DD+4BA & Triple hybrid filter
3D-printed physical bandpass and lowpass filter conduits, along with a resistor and capacitor filter form a triple hybrid filter. Dual Knowles SWFK tweeters handle the highs, the mids are assigned to a proprietary dual Mid-BA driver and a dual 10mm paper diaphragm dynamic transducer takes care of the bass. This design delivers smooth highs, crisp mids, and deep bass for immersive and faithful sound reproduction.
3D printed filter tube
The physical filtering system of the Blessing3 therefore includes a band-pass filter and a low-pass filter. The first is used to modify the response range of the bass and midrange loudspeakers, while the second is used to limit the Q value of the transducers reproducing the midrange and treble. This particular design demands extreme precision in the manufacturing process but achieves incredible sound quality.
A design and robust body
In order to precisely manufacture the complex structure of the Blessing3 without the slightest error, Moondrop has extended its partnership with the company specialized in 3D printing, HeyGears. This combination makes it possible to take advantage of DLP-3D printing with medical grade UV resin, in order to obtain reliable, precise and robust complex-structured enclosures.
Stainless steel front
Blessing3 faceplates are crafted from medical grade stainless steel through a precise CNC milling process and then brushed. The result is a particularly pleasant play of light and shadow. Assembled with the transparent shell printed in 3D, the set offers a magnificent aesthetic, both modern and sober.
Perfectly optimized sound reproduction
The triple-filter structure uses both acoustic filters and a capacitor-resistor filter, preserving phase coherence across most of the audible spectrum while ensuring that each speaker performs within its respective frequencies. In addition, this method ensures incredibly transparent and highly accurate reproduction. On Moondrop's Blessing3 version, the sound gains in texture and authenticity and the bass is enhanced.
MOONDROP BLESSING3 Écouteurs Intra-Auriculaires IEM Triple Haut-Parleurs 14.8 Ohm 120dB 10Hz - 30kHz MOONDROP BLESSING3 Écouteurs Intra-Auriculaires IEM Triple Haut-Parleurs 14.8 Ohm 120dB 10Hz - 30kHz
Product typeIn ear monitors (IEM)
DriversTreble: Knowles SWFK
Midrange: Softears D-MID-A
Bass: Dual 10mm Horizontally Opposed Dynamic Loudspeaker
Impedance14.8Ω @ 1kHz (±15%)
Frequency response10Hz - 30kHz
Effective frequency response20Hz - 20kHz (IEC60318-4)
Sensitivity120dB/Vrms @ 1kHz
THD< 0.5% @ 1kHz
Speaker setup2DD 4BA per side, triple filter
IEM connector0.78mm 2 pins
CableSupplied with a Jack 3.5mm cable to 2x 0.78mm 2 pins
ColorSilver
Impedance (Ω)14.8
Efficiency / Sensitivity (dB)120.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
MOONDROP BLESSING3 In-Ear Monitor IEM Triple Drivers 22 Ohm 117dB 20Hz-20kHz
Moondrop offers with the Blessing3, evolution of the Blessing2, exceptional in-ear headphones, offering a sound reproduction as rich as it is...
