Moondrop's Block are flat-head wireless earphones with dynamic 13mm drivers. The brand's expertise enables it to offer comfortable earphones with a natural sound reproduction.
Moondrop's Block earphones each use a 13mm dynamic driver with a dome made from organic composite materials and a flexible suspension. Coupled with an N52 magnet array and a CCAW voice coil, the Block delivers punchy bass and smooth high frequencies.
In order to offer effective noise reduction during your telephone calls, the Block is equipped with two microphones each for beamforming noise reduction. This technique is based on several microphones picking up the same sound source. However, because they are positioned differently, the interference picked up by each of these microphones will be different, enabling it to be discriminated and eliminated.
Block are flat-head earphones that are easier and more comfortable to wear than their in-ear counterparts. Unlike wired earphones, Block offer a freer user experience and, with the addition of DSP, a more relaxed and enjoyable listening experience.
Moreover, Block's low latency for wireless earphones (<55ms) is matched by a frequency response very similar to that of the VDSF model.
Product type | Flat-head wireless earphones |
Drivers type | Dynamic Ø13mm |
Bluetooth version | 5.4 |
Supported Bluetooth protocols | AAC/SBC |
Bluetooth working distance | 10m (barrier-free open environment) |
Phone calls | Yes |
Autonomy | |
Charging port | USB-C |
Earphone charging time | About 1 Hour |
Charging time of charging case | About 1.5 Hours |
Earphone battery capacity | 3.7V/37mAh |
Battery capacity of charging case | 3.7V/300mAh |
Battery life of earphone | About 6 Hours |
Battery life of charging case | About 15 Hours |
Color | White |
Dimensions | Case : 42.6 x 24.6mm Earphone : 32.2 x 17.7mm |
Package | 1x Moondrop Block |
Color |
Impedance (Ω) |
Efficiency / Sensitivity (dB) |
Lowest frequency (Hz) |
Highest frequency (Hz) |
Wireless |
Cable termination |
Headphone / Earphone connector |
Phone call feature |
Noise reduction |
