By buying this product you get 37 loyalty points
Moondrop Chaconne in-ear monitors feature ultra-high-performance dynamic transducers including a high-efficiency external magnetic circuit, polyurethane composite and liquid crystal polymer (LCP) diaphragm . The TC4 aerospace titanium alloy cutting cavity and gold-plated brass faceplate provide a robust, elegant structure. All connected to a shielded, silver-plated copper coaxial cable, allowing the assembly to unfold its full potential for high-quality sound reproduction.
Moondrop Chaconne earphones feature dynamic transducers combining polyurethane and liquid crystal polymer (LCP). LCP, renowned for its high rigidity and light weight, ensures remarkable hight extension and fuller mids density. The suspension adopts an ultra-thin, flexible polyurethane structure, delivering full, deep bass, even in this compact format. Finally, a high-efficiency external magnetic circuit is also part of the package. This design achieves a natural frequency as low as 120 Hz, guaranteeing optimal sound reproduction that omits no detail while maintaining a balanced frequency response.
The cavity of Moondrop Chaconne earphones is made of aerodynamic TC4 titanium alloy covered with a flocking material that absorbs sound waves emanating from the rear of the driver, converting them into thermal energy to significantly reduce sound wave reflection.
Furthermore, in order to prevent any potential damage to the transducers caused by metal debris being sucked into the magnet due to the holes on the front panel of Moondrop Chaconne earphones, an ingenious protection solution has been put in place. Inside the front plate is a specially designed dustproof filter, featuring a three-section ring that is securely fastened. This clever design acts as an effective barrier against unwanted particles, while preserving the earphone opening. For everyday use, the use of foam tips is recommended to maximize membrane protection.
The cable specially developed for Moondrop Chaconne headphones is constructed from a 6N Litz OCC 24AWG single-crystal copper core, before being covered with a 4N Litz OFC silver-plated shielding layer acting as a negative electrode. This cable guarantees minimal parasitic inductance, for the most faithful sound reproduction possible.
| Specifications | |
| Product type | In-ear monitors |
| Frequency response | 20Hz-20kHz |
| Sensitivity | 124dB/1mW |
| Total harmonic distortion (THD) | <1% @ 1KHz |
| Impedance | 24Ω±15% @ 1kHz |
| Diaphragm materials | Polyurethane Liquid crystal polymer (LCP) |
| Cavity materials | TC4 titanium alloy Gold-plated brass |
| General | |
| Package | 1x Pair of earphones 12x Foam ear-tips 1x Storage bag |
| Color | Silver |
| Impedance (Ω) | 24 |
| Efficiency / Sensitivity (dB) | 124.0 |
| Lowest frequency (Hz) | 20 |
| Highest frequency (Hz) | 20000 |
| Wireless | No |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | Non-detachable cable |
| Phone call feature | No |
| Noise reduction | No |
