MOONDROP CHU In-Ear Monitors IEM Dynamic 10mm with Microphone 120dB 28 Ohm 20Hz-20kHz
Moondrop unveils with the Chu in-ear earphones taking advantage of a very nice design quality and sound reproduction at an exceptionally affordable price. Each IEM features a 10mm diameter dynamic driver with a Nano-Crystal coated composite membrane, decentralized in an acoustically optimized cavity.
Reference : 16491
24,90 €tax incl.
20,75 € tax excl.
Moondrop Chu
Moondrop Chu Écouteurs Intra-Auriculaires IEM Dynamiques 10mm avec Microphone 120dB 28Ω 20Hz-20kHZ
Moondrop unveils with the Chu in-ear earphones taking advantage of a very nice design quality and sound reproduction at an exceptionally affordable price. Each IEM features a 10mm diameter dynamic driver with a Nano-Crystal coated composite membrane, decentralized in an acoustically optimized cavity. These drivers are powered by a motor using a N52 neodymium magnet and an ultra-thin CCAW coil, ensuring excellent efficiency and delivering a sound reproduction as dynamic as rich in details, while remaining faithful to the original signal. The robust Chu headphones have a beautiful die-cast metal body. The eartips eliminate unwanted resonances thanks to a particularly studied structure, significantly reducing the linear distortion of the high frequencies and supporting a natural timbre, while offering a very good comfort of port, adapting perfectly to the shape of the ear. Finally, this model is equipped on its cable with a small control box integrating a microphone, thus making it possible to answer calls easily.
Moondrop Chu review by Crinacle+
Product typeIn-Ear Monitors (IEM)
Driver typeDynamic 10mm
DiaphragmComposite, titanium-coated
MagnetNeodymium N52
Voice coilCCAW 0.035mm
Body materialZinc alloy
Sensitivity120dB/Vrms @ 1kHz
Impedance28Ω ±15% @ 1kHz
THD≤ 1% @ 1kHz
Effective frequency response20Hz - 20kHz (IEC60318-4, -3dB)
Controls / Microphone
ConnectorJack 3.5mm
Impedance (Ω)28
Efficiency / Sensitivity (dB)120.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
Amazing value
Must say I have been surprised by the sound quality in these. Did not expect much with this price tag, but was positively surprised. You can't go wrong with these, if you are looking for a budget/entry level IEM.
This review has been posted for MOONDROP CHU In-Ear Monitors IEM Dynamic 10mm with Microphone 120dB 28 Ohm 20Hz-20kHz
Moondrop unveils with the Chu in-ear earphones taking advantage of a very nice design quality and sound reproduction at an exceptionally affordable...
