Moondrop unveils its Darksaber high-end dynamic in-ear monitors (IEMs). The Darksaber feature two 10mm dynamic drivers and 8 Balanced Armatures drivers (4 for midrange and 4 for treble). The dynamic drivers are arranged in horizontal opposition (H.O.D.D.D.U.S) to reduce linear distortion and provide greater dynamics and responsiveness at low frequencies. The shell of these in-ear headphones is composed of hundreds of layers of carbon fiber, making it durable, lightweight and aesthetically pleasing. Finally, a Litz wire structure cable with silver-plated copper conductors, 0.78mm CIEM connectors and interchangeable termination ensures transmission of the audio signal from the source device to the high-end Moondrop Darksaber monitors.
Darksabers feature 2 dynamic drivers for low frequencies, 4 Balanced Armature drivers for midrange and 4 Balanced Armature drivers for treble. Each driver plays a specific role in processing the audio signal for clear, precise sound reproduction. This is made possible by the internal design of the headphones and a 2-way crossover circuit that gives these earphones excellent performance across the entire frequency range they cover. In addition, the two 10mm dynamic drivers are arranged in horizontal opposition (H.O.D.D.D.U.S - Horizontallly Opposed Dual Dynamic Drivers Unit System) to optimize the drivers' magnetic fields for better energy/efficiency conversion and reduced levels of linear distortion. Moondrop has also applied precise, professional-quality acoustic tuning to the Darksabers.
Moondrop's Darksaber in-ear monitors benefit from a constant, linear frequency response phase for an overall natural timbre and to facilitate the correct distribution of the various frequencies to the dynamic drivers that make them up. As a result, Darksaber earphones offer a wide soundstage and authentic timbre.
Darksabers come with a high-quality cable. It features a Litz wire structure with silver-plated copper conductors. On both sides of the cable are standard CIEM 0.78mm connectors and a termination with interchangeable jack connectors: 3.5mm jack and balanced 4.4mm jack.
Make sure you connect the 3.5mm or 4.4mm jack terminals the right way around. A visual mark consisting of an arrow is present on both elements.
| Specifications | |
| Product type | In-ear monitors (IEM) |
| Spekers/Drivers | 2x 10mm Dynamic Drivers (Bass) 4x Custom Balanced Armatures drivers (Midrange) 4x Knowless SWFK Balanced Armatures Drivers (Treble) |
| Impedance | 22Ω ±15% (@1kHz) |
| Sensitivity | 128dB/Vrms (@1kHz) |
| THD | ≤ 1% (@1kHz) |
| Effective frequency response | 20Hz-20kHz (IEC60318-4, 3dB) |
| Frequency response | 7Hz-20kHz (IEC61094, free field) |
| Earphones terminaisons | CIEM 2-pin 0.78mm |
| Cable structure | Litz wire |
| Cable conductor material | Copper alloy |
| Cable conductors plating | Silver |
| Câble terminaison | Interchangeable (3.5mm jack & balanced 4.4mm jack) |
| General | |
| Color | Transparent |
| Package | 1x Moondrop Darksaber in-ear monitors 1x 0.78mm CIEM cable to interchangeable termination 1x 3.5mm jack termination 1x 4.4mm balanced jack termination |
| Impedance (Ω) | 22 |
| Efficiency / Sensitivity (dB) | 128.0 |
| Lowest frequency (Hz) | 20 |
| Highest frequency (Hz) | 20000 |
| Wireless | No |
| Cable termination | Jack 4.4mm |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | CIEM |
| Phone call feature | No |
| Noise reduction | No |
