Moondrop unveils with the Jiu in-ear monitors benefiting from a very good quality of design and sound reproduction at an exceptionally affordable price. Each IEM embeds a 10mm diameter dynamic driver with composite membrane with Nano-Crystal coating, decentralized in an acoustically optimized cavity. These loudspeakers are powered by a motor using an N52 neodymium magnet and an ultra-thin CCAW coil, ensuring excellent performance and offering a sound reproduction that is as dynamic as it is rich in detail, while remaining faithful to the original signal. Robust, these Jiu headphones have a molded and injected metal body with the most beautiful effect. The tips allow them to eliminate unwanted resonances thanks to a particularly studied structure, significantly reducing the linear distortion of high frequencies and favoring a natural tone, while offering a very good wearing comfort, adapting perfectly to the shape of the body. 'ear. Finally, this model is equipped on its cable with a small control box incorporating a microphone, thus making it easy to answer calls.
The Moondrop Jiu have a frequency response of 10Hz -35kHz and will allow you to enjoy rich and detailed sound. We will also note their sensitivity of 110dB.
These headphones integrate a DSP chip into the USB interface to create a purer listening experience with natural sound and pleasing bass.
Product type | In-ear monitors (IEM) |
Speaker type | Dynamic 10mm |
Diaphragm | Composite diaphragm, titanium coating |
Magnet | Neodymium N52 |
Coil | CCAW 0.035mm |
Body material | Zinc Alloy |
Sensitivity | 110dB/Vrms @ 1kHz |
THD | ≤ 1% @ 1kHz |
Frequency response | 10Hz -35kHz (IEC61094) |
Effective frequency response | 20Hz-20kHz (IEC60318-4, -3dB) |
Controls / Microphone | |
Connector | USB-C |
Color | Black |
Impedance (Ω) | NC |
Efficiency / Sensitivity (dB) | 110 |
Lowest frequency (Hz) | 10 |
Highest frequency (Hz) | 35000 |
Wireless | No |
Cable termination | USB-C |
Headphone / Earphone connector | Non-detachable cable |
Phone call feature | Yes |
