MOONDROP JIU USB-C Dynamic IEM In-Ear Headphones USB-C DSP with Microphone Ø10mm 110dB 10Hz-35kHz
Moondrop unveils with the Jiu in-ear monitors benefiting from a very good quality of design and sound reproduction at an exceptionally affordable price. Each IEM embeds a 10mm diameter dynamic speaker with composite membrane with Nano-Crystal coating, decentralized in an acoustically optimized cavity. These loudspeakers are powered by a motor using an N52 neodymium magnet and an ultra-thin CCAW coil, ensuring excellent performance and offering a sound reproduction that is as dynamic as it is rich in detail, while remaining faithful to the original signal.
Reference : 17676
26,90 €tax incl.
22,42 € tax excl.
MOONDROP JIU
MOONDROP JIU USB-C Dynamic DSP IEM In-Ear Headphones with Microphone 10mm 110dB 10Hz-35kHz
Moondrop unveils with the Jiu in-ear monitors benefiting from a very good quality of design and sound reproduction at an exceptionally affordable price. Each IEM embeds a 10mm diameter dynamic driver with composite membrane with Nano-Crystal coating, decentralized in an acoustically optimized cavity. These loudspeakers are powered by a motor using an N52 neodymium magnet and an ultra-thin CCAW coil, ensuring excellent performance and offering a sound reproduction that is as dynamic as it is rich in detail, while remaining faithful to the original signal. Robust, these Jiu headphones have a molded and injected metal body with the most beautiful effect. The tips allow them to eliminate unwanted resonances thanks to a particularly studied structure, significantly reducing the linear distortion of high frequencies and favoring a natural tone, while offering a very good wearing comfort, adapting perfectly to the shape of the body. 'ear. Finally, this model is equipped on its cable with a small control box incorporating a microphone, thus making it easy to answer calls.
Good frequency response
The Moondrop Jiu have a frequency response of 10Hz -35kHz and will allow you to enjoy rich and detailed sound. We will also note their sensitivity of 110dB.
An integrated DSP Chip (Digital Signal Processing)
These headphones integrate a DSP chip into the USB interface to create a purer listening experience with natural sound and pleasing bass.
Product typeIn-ear monitors (IEM)
Speaker typeDynamic 10mm
DiaphragmComposite diaphragm, titanium coating
MagnetNeodymium N52
CoilCCAW 0.035mm
Body materialZinc Alloy
Sensitivity110dB/Vrms @ 1kHz
THD≤ 1% @ 1kHz
Frequency response10Hz -35kHz (IEC61094)
Effective frequency response20Hz-20kHz (IEC60318-4, -3dB)
Controls / Microphone
ConnectorUSB-C
Impedance (Ω)NC
Efficiency / Sensitivity (dB)110
Lowest frequency (Hz)10
Highest frequency (Hz)35000
WirelessNo
Cable terminationUSB-C
Headphone / Earphone connectorNon-detachable cable
Phone call featureYes
Moondrop unveils with the Jiu in-ear monitors benefiting from a very good quality of design and sound reproduction at an exceptionally...
