MOONDROP LAN In-Ear Monitors IEM Dynamic 10mm 120dB 32 Ohm 15Hz-37KHz
Moondrop unveils dynamic in-ear headphones with the LAN, featuring a compact stainless steel shell and a changeable cable. These IEM headphones, although very affordable in terms of price, nevertheless embed technologies used in the high-end Hi-Fi allowing a beautiful sound reproduction.
4.5 / 5
Reference : 17418
49,00 €tax incl.
40,83 € tax excl.
Shipping date: 23-04-2025.
Moondrop lan
In-Ear Monitors IEM Dynamic 10mm 120dB 32 Ohm 15Hz-37kHz
Moondrop unveils dynamic in-ear headphones with the LAN, featuring a compact stainless steel shell and a changeable cable. These IEM headphones, although very affordable in terms of price, nevertheless embed technologies used in the high-end Hi-Fi allowing a beautiful sound reproduction. The speakers are equipped with a new generation of diaphragm with Beryllium coated composite membrane and are powered by a motor that uses a N52 magnet and an ultra-thin 0.03mm CCAW coil. In addition, the internal brass acoustic cavity provides a neutral tone and a clear and precise sound. The assembly of these different technical elements allows this model of in-ear earphones to cover a wide range of frequencies while limiting their level of linear distortion. Another special feature of this model is that you have the possibility to change the cable to meet various uses; simple cable, cable with built-in microphone for your phone calls and gaming, bluetooth adapter for outdoor listening. To conclude, the quality of the sound rendering as well as their robustness make them very good headphones whether you are music lovers, gamer or professional.
Product typeIn-Ear Monitors (IEM) with repleceable cable
Driver typeDynamic 10mm (high performance)
DiaphragmComposite, Beryllium-coated
MagnetN52 magnet
Voice coilCCAW 0.03mm
Body materialStainless steel shell
Sensitivity120dB/Vrms @ 1kHz
Impedance32 Ω ±15% @ 1kHz
THD≤0.5% (@1kHz, 94dB)
Frequency response15Hz - 37kHz (IEC60318-4, -3dB)
Effective frequency response20Hz - 20kHz (IEC60318-4, -3dB)
Acoustic filterPatented anti-blocking filter
Headphone connector0.78mm 2 pin
Cable connectorAngled Jack 3.5mm
ColorSilver
Impedance (Ω)32
Efficiency / Sensitivity (dB)120.0
Lowest frequency (Hz)15
Highest frequency (Hz)35000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
2 reviews
Complémentaire au Chu 2.
Les + :
- Construction semble robuste.
- Confort, légèreté.
- Timbre, neutralité.
- Définition et scène supérieures à la moyenne.
Les - :
Pas pour amateur de basse charnue.
Bonne séparation mais devient confuse en présence de trop d'informations et lorsque le volume augmente.
Conclusion :
Clarté et scène holographique sont au rendez-vous.
Les Moondrop Lan sont axés sur une écoute critique, neutre et sans coloration.
Plus technique et défini que le Chu 2 .
This review has been posted for MOONDROP LAN In-Ear Monitors IEM Dynamic 10mm 120dB 32 Ohm 15Hz-37KHz
Sympa
Une valeur sûr !
Aigus un peu en avant mais pas trop. Semble super solide.
Seul petit point regrettable la boîte est super grande mais y'a que 3 paires d'ambouts.. Plus d'embouts et une boite moins tape à l'oeil ça aurait été pas mal.
Moondrop unveils dynamic in-ear headphones with the LAN, featuring a compact stainless steel shell and a changeable cable. These IEM headphones,...
