With Moca, Moondrop offers us wireless earphones equipped with a dynamic 10mm driver with a ceramic and titanium nitride membrane, ensuring a sound experience that is both soft and precise. The Moca headphones feature noise cancellation based on hybrid technology, with particular attention paid to the acoustic duct to avoid wind noise as much as possible. Finally, a real effort has been made to make the user experience as pleasant as possible, whether through automatic detection of earphone wear or wireless recharging of the box.
Moca in-ear earphones feature a new composite membrane with a titanium nitride and ceramic coating developed by Moondrop's R&D team. The two-stage treatment of the materials that make up the membrane ensures a smooth high-frequency response, superior to that of a metal-coated membrane, as well as ultra-low distortion. The result is a sound full of detail and treble without any granularity or roughness.
This new 10mm driver also features a magnetic circuit made up of N52 magnets and a CCAW Daikaku voice coil, ensuring excellent sensitivity and a wide frequency response while maintaining low distortion.
The active noise suppression of Moca earphones is based on a hybrid FF + FB (Feedforward + Feedback) technology that uses both the surrounding noise and an analysis of the signal emitted to produce a signal with the opposite phase to the unwanted noise detected. This is complemented by an acoustic duct designed to greatly limit the wind noise that could be picked up by the external microphone, completing a noise suppression system that is effective in all circumstances. Furthermore, a transparency mode is also available, so you can listen to your favourite tracks while being aware of your surroundings.
The charging case has a lid-open detection function, so the earphones automatically reconnect to the paired device as long as the case is open. When the lid is open, a long press on the pairing button at the bottom of the charging case allows new devices to be paired.
The Moca charging case is compatible with wireless charging. Simply place the side marked with the wireless charging symbol on the charging device (wireless charger not supplied).
Thanks to the compact 10mm dynamic driver with wide bandwidth and low distortion, the MOCA has enough space to integrate a photosensitive sensor, enabling fine detection of when the earphone is being worn or not. Allowing your music to be paused automatically when you remove the earphones.
Furthermore, if one earphone is removed while noise-cancellation mode is active, the other earphone will automatically switch to transparent mode for a more comfortable user experience.
Moca earphones also support the LC3 codec (Low Complexity Communications Codec). This is a new-generation codec based on LE Audio technology. It is different from the traditional Bluetooth codec and offers the advantages of high stability, low delay, low power consumption and high sound quality.
Furthermore, Moca has a low latency time for wireless earphones (<55ms) and a frequency response very similar to that of the VDSF model.
Thanks to the MOONDROP Link application, available on Android and iOS, you can customise a number of features, such as the order in which noise reduction mode and transparency mode are activated, or whether the LC3 codec is used. Furthermore, you can select several frequency response profiles, leaving more or less room for low frequencies.
Product type | True Wireless In-Ear Monitor (IEM) |
Drivers type | Dynamic Ø10mm |
Bluetooth version | 5.4 |
Supported Bluetooth protocols | SBC / AAC / LC3 |
Bluetooth working distance | 10m (barrier-free open environment) |
Phone calls | Yes |
Autonomy | |
Charging port | USB-C / Wireless charging |
Earphone charging time | 1.5h |
Case charging time | 2h |
Battery life of earphone | 6h |
Battery life of charging case | 15h |
Color | Brown |
Package | 1x Moondrop Moca 1x Charging case 3x Pairs of silicone eartips (S, M et L) 1x USB-C cable |
Color | Brown |
Impedance (Ω) | NC |
Efficiency / Sensitivity (dB) | N/A |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 20000 |
Wireless | Yes |
Cable termination | Wireless |
Headphone / Earphone connector | Wireless (Bluetooth) |
Phone call feature | Yes |
Noise reduction | Yes |
