MOONDROP STELLARIS In-Ear Monitors IEM Planar Magnetic 36Ω 117dB 20Hz-20kHz
The Moondrop Stellaris in-ear earphones are equipped with a Planar Magnetic transducer, offering excellent sound performance, with particularly detailed and precise reproduction. The speaker design selected here ensures very low distortion and high stability.
Reference : 16947
109,00 €tax incl.
90,83 € tax excl.
Moondrop Stellaris
Moondrop Stellaris Écouteurs Intra-Auriculaires IEM Planar Magnetic 36Ω 117dB 20Hz-20kHz
The Moondrop Stellaris in-ear earphones are equipped with a Planar Magnetic transducer, offering excellent sound performance, with particularly detailed and precise reproduction. The speaker design selected here ensures very low distortion and high stability. To accommodate this type of driver, the acoustic structure of the Stellaris was carefully designed to precisely control the resonant frequency of the assembly while improving linear distortion performance, creating a more natural sound reproduction.
High precision N52H magnet array
The Stellaris' fully balanced magnetic circuit consists of 7+7 N52H magnets. Precisely arranged, this design delivers very low harmonic distortion and high magnetic flux for a very clear sound.
Sub-nanometric diaphragm
The Stellaris IEMs are equipped with a 1µm thick, uniformly tensioned sub-nanometer diaphragm. The membrane vibrates in a perfectly uniform manner, ensuring a transparent and detailed sound reproduction.
1Patented design screw
2Rear shell
3External damping
4Extra tuning acoustic cavity
5Internal damping
6PCB
7Subnanometric
8Structural frame
9Magnet grid array
10Metal filter
11Driver shell
122 pins 0.78mm connector
13Decompression damping
14Front cavity
15Tuning sponge
16MIS eartips
Product typeIn-ear monitors(IEM)
DriversPlanar Magnetic 14.5mm
IEM ConnectorsCIEM 0.78mm 2 pins
Cable connectorJack 3.5mm
Sensitivity117dB/Vrms @ 1kHz
Impedance36Ω ±15% @ 1kHz
Frequency response20Hz-20kHz
ColorBlue
PackageMoondrop Stellaris IEM
Memory foam eartips
Softears silicon eartips
ColorBlue
Impedance (Ω)36
Efficiency / Sensitivity (dB)117.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
The Moondrop Stellaris in-ear earphones are equipped with a Planar Magnetic transducer, offering excellent sound performance, with particularly...
