MOONDROP U2 Earphones
With the U2 earphones, Moondrop continues the tradition of quality design and manufacture that has made the brand so successful. With a 14.8mm dynamic driver with a paper diaphragm and a resonance tube inspired by the first acoustic tubes, these earphones offer high-quality sound reproduction coupled with excellent wearing comfort at a very affordable price.
Reference : 19279
41,90 €tax incl.
34,92 € tax excl.
Shipping date: 23-04-2025.
MOONDROP U2 Earphones Dynamic 14.8mm 116dB 30Ω 20Hz-20kHz
MOONDROP U2 : Front view
With the U2 earphonesMoondrop continues the tradition of quality design and manufacture that has made the brand so successful. With a 14.8mm dynamic driver with a paper diaphragm and a resonance tube inspired by the first acoustic tubes, these earphones offer high-quality sound reproduction coupled with excellent wearing comfort at a very affordable price.
MOONDROP U2 : Transparent view of the driver
Moondrop U2 : Paper diaphragm
Moondrop's U2 earphones feature a composite diaphragm with a flexible polyester suspension. The cone-dome structure of the U2 is made from compressed cellulose pulp, the same material used in professional drivers because of its high rigidity and internal strength. What's more, these earphones adopt the same ‘suspension-cone-dome’ diaphragm structure as our full-range drivers. Combined with a flexible polyester suspension, this structure gives a much better and more balanced frequency response than ordinary earphones, resulting in fine detail and a smooth, natural timbre.
Moondrop U2 : 14.8mm dynamic driver
Equipped with an N52 magnetic circuit and a lightweight CCAW voice coil, the 14.8mm-diameter dynamic driver fitted to the U2 earphones combines comfort of use with admirable performance. The pairing of the U2's efficient design and this driver delivers punchy bass, low distortion, wide dynamic range and fast treble response.
Moondrop U2 : A custom-made acoustic tube
The U2 earphones feature a U-shaped acoustic tube, a tribute to the pioneers of acoustic design. The structure has been optimised and improved using modern manufacturing technologies, optimising the resonance effect of the brass tube at low frequencies. As a result, this true resonance chamber offers a unique timbre while attenuating the pressure of the bass, allowing you to enjoy it without having to absorb any of it first.
MOONDROP U2 : Atmospheric pressure inside the earphone
Product typeEarphones
Driver typeDynamic Ø14.8mm
Membrane materialComposite paper
MagnetNeodymium N52
Voice coilCCAW
Body materialAcrylonitrile butadiene styrene (ABS)
Sensitivity116dB/Vrms @ 1kHz
Impedance30Ω±15% @ 1kHz
Total harmonic distortion (THD)≤0.1% @ 1kHz 94dB
Cable connector3.5mm Jack
Package1x Moondrop U2
1x Storage Bag
5x Pair of ear tips
Impedance (Ω)30
Efficiency / Sensitivity (dB)116.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorNon-detachable cable
Phone call featureNo
Noise reductionNo
Excellent pour le prix !
Une fois leur placement bien déterminé dans l'oreille, car ils ne sauront pas s'adapter à toutes les formes (je pense aux petites !), le son est épatant. Très belle linéarité, ce qui est rare pour des écouteurs intra.
Le tube "bass reflex" fonctionne très bien, les basses sont généreuses et précises.
C'est à la lecture de la fiche technique que je me suis laissé tenté car n'étant pas fan des oreillettes (amateur des HD 600 & 530…).
Bref, ils sont devenus mes compagnons pour l'extérieur dorénavant.
This review has been posted for MOONDROP U2 Earphones Dynamic 14.8mm 116dB 30Ω 20Hz-20kHz
With the U2 earphones, Moondrop continues the tradition of quality design and manufacture that has made the brand so successful. With a 14.8mm...
