MOONDROP x CRINACLE DUSK In-Ear Monitors
MOONDROP x Crinacle DUSK in-ear monitors are IEMs with a multi-driver configuration. They feature 2 dynamic drivers, 2 balanced armature drivers and 2 planar magnetic drivers.
By buying this product you get 35 loyalty points
Reference : 19816
359,00 €tax incl.
299,17 € tax excl.
Moondrop x Crinacle Dusk In-ear Monitor IEM Dynamic Planar Magnetic 14.5 ohm 119dB 10Hz-24kHz
MOONDROP x Crinacle DUSK picture
Moondrop x Crinacle Dusk in-ear monitors are IEMs with a multi-driver configuration. They feature 2 dynamic drivers, 2 balanced armature drivers and 2 planar magnetic drivers. The planar magnetic drivers deliver low-distortion sound reproduction with smooth, detailed highs, while the Ø10mm dynamic drivers benefit from a H.O.D.D.D.U.S (“Horizontally-Opposed Double Dynamic Driver Module”) layout for deep bass. These headphones feature standard CIEM 0.78mm connectors and two detachable cables: a 3.5mm jack-terminated cable and a USB-C-terminated cable featuring a DAC/DSP chip. The USB-C cable supports sampling rates up to PCM 32bit 384kHz and the Moondrop Link 2.0 application. The Dusk IEMs are quality headphones with a wide range of features.
Exploded view of MOONDROP x Crinacle DUSK
Moondrop x Crinacle Dusk: 2DD + 2BA + 2Planar configuration
The combination of these different drivers produces a balanced sound reproduction with detailed highs and deep bass. The two planar magnetic drivers handle the treble, the balanced armatures the midrange, while the two Ø10mm dynamic drivers in H.O.D.D.U.S configuration handle the bass. The use of planar magnetic drivers significantly reduces the level of distortion.
Photo of the dynamic drivers layout
Moondrop x Crinacle Dusk: H.O.D.D.D.U.S configuration
The symmetrical configuration of the dynamic drivers acts on their magnetic field to reduce the level of non-linear distortion. In addition, their paper dome avoids undesirable resonance effects for a natural rendering.
Moondrop x Crinacle Dusk: 3.5mm jack & USB-C termination
Two cables are supplied with the Dusk. A classic cable with 3.5mm jack termination and a USB-C cable. The USB-C cable features an integrated DAC/DSP. Coupled with the Moondrop Link 2.0 application, it supports sampling rates up to PCM 32bit 384kHz. In addition, 5 types of acoustic settings are available, allowing you to fine-tune the final sound.
Photo of MOONDROP x Crinacle DUSK cables
Moondrop x Crinacle Dusk: Moondrop Link 2.0 application
The Moondrop Link 2.0 application provides access to an interactive DSP. This DSP lets you configure customized equalization, as well as take advantage of various standard profiles pre-recorded by the brand or by users of the application.
Please note that iOS devices do not allow you to share your configurations online, due to iOS restrictions.
Photo of MOONDROP LINK 2.0 app interface
Product typeIn-ear monitors (IEM)
Drivers2x Dynamic
2x Balanced Armature
2x Planar magnetic
Fréquency response10Hz-24kHz
Effective frequency response20Hz-20kHz
Impedance14.5 ohm ±15% @ 1kHz
Sensitivity119dB/Vrms @ 1kHz
THD≤0.5% @ 1kHz
Earphone connectorCIEM 0.78mm
Cable terminaison1x USB-C cable
1x 3.5mm jack cable
Supported sampling rate of USB-C cablePCM 32bit 384kHz
ApMoondrop Link 2.0
ColorBlack (wood)
Package1x Pair of Moondrop x Crinacle Dusk earphones
1x 3.5mm jack termination cable
1x USB-C termination cable
3x Pair of in-ear tips
1x Leather pouch
Impedance (Ω)14.5
Efficiency / Sensitivity (dB)119
Lowest frequency (Hz)10
Highest frequency (Hz)24000
MOONDROP x CRINACLE DUSK In-Ear Monitor IEM Dynamic Planar Magnetic 14.5 ohm 119dB 10Hz-24kHz
MOONDROP x Crinacle DUSK in-ear monitors are IEMs with a multi-driver configuration. They feature 2 dynamic drivers, 2 balanced armature drivers...
