NF Audio NM2+ in-ear monitors are dynamic IEMs based on the use of a NF2L-10II dynamic diaphragm in 5u polymer composite. This diaphragm features various advantages such as an integrated tuning circuit for improved timbre, a dual NIB magnet circuit for enhanced sensitivity, dynamics and transient response, as well as a dual acoustic cavity design for precise control of internal airflow pressure. The NM2+ also offer a fairly flat frequency response, with deep bass and detailed highs. As an added bonus, NF Audio has equipped these headphones with 25dB of passive noise reduction, enabling users to hear every detail of their favorite tracks. The NM2+'s 18-ohm impedance and 108dB sensitivity make them easy to drive. In addition, an audiophile cable with silver-plated OFC 5N copper conductors and a litz wire structure accompanies the NM2+. This cable features 0.78mm CIEM connectors and a 3.5mm jack termination. A 3.5mm jack to 6.35mm jack adapter is also included for a high level of compatibility.
The NM2+ driver's integrated tuning circuit offers greater stability and reliability, as well as improved timbre in the final sound.
The NM2+ benefits from a double magnetic circuit with NIP magnet for a considerable increase in magnetic flux and, consequently, better driveability, dynamics and transient response.
The NC2L-10II driver's dual acoustic cavity provides better control of acoustic pressure for smoother diaphragm movement and richly detailed rendering. As a result, mids and vocals are clear and transparent, while highs are extended. Bass, too, is not left out of the equation: powerful, it allows a high level of immersion while listening to a piece of music.
The NM2+ diaphragm, made of 5u polymer composite, is lightweight and semi-rigid, helping to avoid distortion in sound reproduction.
The frequency response of the NF Audio NM2+, thanks to their design, ensures that the sound restitution remains faithful to the source. In fact, their design and professional level control allow them to act as backstage headphones. Their fairly linear frequency response delivers pleasant, high-performance sound. The in-ear tips supplied allow you to obtain a balanced sound reproduction, or one with more bass.
The NM2+'s 25dB passive noise reduction provides a detailed listening experience for the user, without the need to increase the volume considerably in the presence of external noise.
The 0.78mm CIEM patch cable to 3.5mm jack termination supplied with the NM2+ features OFC 5N copper conductors and a litz wire structure for a total of 280 strands. The result is reliable, stable signal transmission. A 3.5mm jack to 6.35mm jack adapter is also supplied. This high-quality adapter features an aluminum body and gold-plated contacts for resistance to corrosion and oxidation.
The ergonomic design and light weight of the NM2+ provide a considerable level of comfort for the user. Their shell has been designed using the 5-axis CNC machining process for a superior level of precision.
Product type | In-ear monitors |
Driver type | Dynamic with dual-cavity |
Frequency response | 10Hz-40kHz |
Impedance | 18 ohm |
Sensitivity | 108dB/mW |
SPL max. | 125dB |
Passive noise reduction | 25dB |
Distorsion | < 1% |
Color | Silver |
Weight | 300g |
Package | 1x NF Audio NM2+ in-ear monitors 1x Detachable 0.78mm CIEM cable to 3.5mm jack termination 1x 3.5mm jack to 6.35mm jack adapter 6x In-ear tips 1x Storage pouch |
Color | Silver |
Impedance (Ω) | 18 |
Efficiency / Sensitivity (dB) | 108 |
Lowest frequency (Hz) | 10 |
Highest frequency (Hz) | 40000 |
Wireless | No |
Cable termination | Jack 6.35mm |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
