NF ACOUS NM20 In-Ear Monitor Grey
With the NM20, NF ACOUS presents us with in-ear earphones designed for professional use, offering a very neutral frequency response. A direct descendant of the NM2, these earphones take everything that made the previous model such a success, while improving the driver, structure and user experience.
Reference : 20211
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 01-04-2025.
NF ACOUS NM20 Dynamic In-Ear Monitor IEM 32Ω 108dB 9Hz-40kHz Grey
Picture of NF ACOUS NM20 earphones
With the NM20, NF ACOUS presents us with in-ear monitors designed for professional use, offering a very neutral frequency response. A direct descendant of the NM2, these earphones take everything that made the previous model such a success, while improving the driver, structure and user experience.
NF ACOUS NM20: MC2L-100P driver
The NM20 features a dynamic driver with a beryllium-plated diaphragm, accompanied by a double neodymium magnetic circuit and a double acoustic chamber. Uniquely, this driver is driven by a high-precision PCB to ensure identical sound reproduction in all circumstances.
NF ACOUS NM20 : Driver
NF ACOUS NM20 : Clutter Trap
NF ACOUS NM20: Clutter trap
The NM20 earphones also feature the company's proprietary 'Clutter Trap' technology. This consists of a set of 5 air pressure damping nets and 2 attenuation sponges to prevent sound refraction. The result is equivalent pressure between the front and rear of the earphone cavity, for a sound reproduction as close as possible to the original.
NF ACOUS NM20: Polycarbonate and aluminum structure
NM20s are made of high-strength polycarbonate (PC) with a frosted surface for a beautiful matte finish. The metal surround is CNC-machined aluminum. Finally, the 0.78mm connectors have been redesigned for simpler connection and greater durability.
NF ACOUS NM20 : Macro view of connector
NF ACOUS NM20: Neutral frequency response
The NM20 have been designed with professional use in mind, so they benefit from a very neutral frequency response, reproducing the original music as closely as possible. To achieve this, NF ACOUS deploys a range of techniques to obtain good bass below 100Hz, evenly covering the whole audible spectrum.
NF ACOUS NM20 : frequency response
Test des NF ACOUS NM20 par Headfonics
"The NF ACOUS NM20 single dynamic driver IEM excels in technical performance, delivering good detail retrieval, expansive soundstage, and precise imaging. Its sub-bass rumble and detailed treble provide an engaging listening experience that captures intricate nuances in tracks."
Product typeIn-ear monitors (IEM)
Driver typeDynamic
Earphone connectionCIEM 0.78mm
Sensitivity108dB
Impedance32Ω
Sound Insulation25dB
Frequency Response9-40kHz
Total harmonic distortion (THD)< 1%
Maximum acoustic pressure125dB
ColorGrey
Weight300g
Package1x NF ACOUS NM20
1x 3.5mm jack to CIEM 0.78mm OFC copper cable
1x Storage case
1x Jack 3.5mm to Jack 6.35mm adapter
4x Pairs of earphone tips
ColorGray
Impedance (Ω)32
Efficiency / Sensitivity (dB)108
Lowest frequency (Hz)9
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 6.35mm
Phone call featureNo
Noise reductionNo
With the NM20, NF ACOUS presents us with in-ear earphones designed for professional use, offering a very neutral frequency response. A direct...
