SHANLING ME700 LITE In-Ear Monitor IEM Hi Res 106dB 18 Ohm
Ultra light in-ear-monitor equiped with 5 transducers with custom Armature drivers. Removable cable with MMCX connecteurs and balanced / single-ended output.
Reference : 14841
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 17-04-2025.
Shanling ME700 Lite
Earphones transducers 5x driver / 3-way
The best audio technologies in an extremely light case (6.8g), the Shanling ME700s uses no less than five transducers per channel, including 4 custom Armature transducers to offer breathtaking sound reproduction.
The second version of the ME700 series, the LITE model now incorporates a dynamic titanium diaphragm instead of the gold plated diaphragm or to deliver neutral, clean and punchy bass. The white case with gold logo gives it a much brighter look than the first ME700 of the name.
5 transducers in three-way crossover per channel
Each ear-plug is first equipped with a large dynamic transducer dedicated to bass. The latter works with a titanium diaphragm. If the latter is not as efficient as the gold-plated model of its predecessor in absorbing vibrations, it nevertheless offers an increased dynamic range in the low frequencies.
In addition to the dynamic transducer, the ME700 headset uses four symmetrical Armature transducers. The first pair is dedicated to mid / treble while the second pair of transducers delivers the higher frequencies of the audio spectrum. Each of these Armature transducers is a custom version which was modified to strictly comply with Shanling specifications to offer the performance.
The transducers are arranged so as to compensate for the frequency response differentials between one another and with the diaphragm. This design helps to get the most out of each transducer while canceling out phase and time distortion effects. The result is an extremely large and detailed sound image with natural and coherent audio reproduction.
Shanling's ME700s include very high performance Knowless Armature TWFK-30017 transducers. This model is particularly appreciated in the world of IEM for its level of detail in the medium / high range without exaggerated brightness or aggressiveness at the higher top of the spectrum. This allows greater signal clarity without causing listening fatigue.
Hybrid cable combineing silver-plated and gold-platedcopper
The M700 Lite are delivered with an excellent quality cable with gold plated copper conductor combined with silver plated copper conductors. These conductors ensure crystal-clear signal transmission while maintaining exceptional conductor longevity.
All connectors have a SUS316F stainless steel structure (often used in on-board systems in aeronautics). Resistant to impact as well as corrosion, it is an ideal choice for all sensitive moving parts.
TypeIEM
transducersx5
(Dynamic 1x + 4x Armature custom)
Connectors3.5mm Jack
Cable1.2M (removable)
Frequency response20-40 000Hz
Impedance18Ω
Package contents
EMI ME700 Litex1
Tips (pairs)x1
leather casex1
Cable (removable) 3.5mmx1
Brush Maintenancex1
ColorWhite
Impedance (Ω)18
Efficiency / Sensitivity (dB)106.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorMMCX
Phone call featureNo
Noise reductionNo
Ultra light in-ear-monitor equiped with 5 transducers with custom Armature drivers. Removable cable with MMCX connecteurs and balanced /...
