Écouteurs Intra-Auriculaires IEM Bluetooth 5.0 Red
MTW100 V2
Direct connection
Each earphone is directly connected to the source, offering a more stable transmission with reduced delay.
MTW100 V1
Secondary connection
Only the right earpiece is connected to the source. The left earphone is connected in series with the right earphone to receive the signal.
The touch controls for Surrounding Awareness mode and Factory Reset have been adjusted.
Shanling MTW100 V2 in-ear headphones using Knowles symmetrical armature speakers enjoy a significant autonomy of 7h for a single charge. The integrated box also includes a battery, it extends this autonomy to 24h. In addition, these IEMs charge very quickly, 1h30 sufficient for a full charge
The MTW100 V2 integrates a Bluetooth 5.0 chip, allowing fast and stable transmission of data and audio signals while significantly reducing battery consumption. A high-performance ceramic antenna ensures constant signal reception, avoiding interruptions during your listening sessions. Finally, this chip supports AAC and SBC codecs, making MTW100 V2 compatible with all Bluetooth devices.
With Surrounding Awareness Mode, you can enjoy your music while hearing the sounds of your environment. Ideal for example when you are travelling in an urban and potentially dangerous environment.
Knowles symmetrical armature speakers, renowned for their ability to deliver rich, detailed sound while offering high sensitivity, will allow you to rediscover your favorite songs during long listening sessions.
The MTW100 V2 features a built-in microphone so you can easily answer your calls. This microphone is combined with an advanced DSP system, reducing ambient noise and preserving a natural voice timbre.
The MTW100 earphones pair and connect automatically once they are taken out of their transport and charging box. No additional steps are required, just play your music via Bluetooth from your favorite application.
The MTW100 V2 IEMs can be used in Mono or Stereo mode. Stereo mode allows you to enjoy your music to the fullest, while mono mode allows you to use the headphones independently, allowing you to answer a call without cutting yourself off from your environment.
The very low weight and the specially designed shape of the MTW100 V2 allow a comfortable use. The earphones fit perfectly to the shape of the ear and the ear canal for optimal fit.
The intelligent design of the MTW100 V2 allows them to take advantage of the IPX7 leakproof standard, effectively protecting them from water and even complete submersion.
While MTW100 V2 allow wireless audio transmission, they also allow wireless charging. Indeed, the headphone box, with its built-in battery, can be charged simply by placing it on any standard wireless charger (wireless charger not included). Of course, it is also possible to recharge it in a more traditional way, using a USB-C cable.
The Shanling MTW100 V2 is compatible with all Bluetooth devices capable of connecting to Bluetooth headsets.
Product type | In-Ear Monitors (IEM) |
Connection / transmission | Bluetooth |
Bluetooth version | 5.0 |
Max. transmission distance | 10m |
Supported Bluetooth codecs | SBC AAC |
Supported bluetooth protocols | HSP, HFP, A2DP, AVRCP, SPP, PBAP |
IEM battery life | 7h |
IEM + Charging case battery life | 24h |
IEM charging time | 1h30 |
Case charging time | 1h30 |
Drivers | Knowles Balanced Armature |
Integrated microphone | |
Controls | Tactiles |
Waterproofing standard | IPX7 |
Dimensions (one IEM) | 23.1 x 17.2 x 22mm |
Weight (one IEM) | 4.7g |
Dimensions (charging case) | 56 x 25 x 30mm |
Weight (charging case | 39.5g |
Total weight | 48.9g |
Color | Black |
Package | Shanling MTW100 V2 Charging case Charging cable IEM eartips User guide Hand strap |
Color | Red |
Impedance (Ω) | NC |
Efficiency / Sensitivity (dB) | N/A |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | N/A |
