SHANLING MTW200 PLUS Wireless In-Ear Monitors
With the MTW200 Plus, Shanling presents us with wireless in-ear earphones. The brand has opted for a dynamic 10mm driver with a titanium membrane, coupled with a special acoustic chamber designed to protect the driver from interference caused by Bluetooth components. These components are assigned to Qualcomm's QCC3072 chip, providing access to the Bluetooth 5.3 standard and support for the aptX Adaptive and aptX codecs.
3.3 / 5
Reference : 19877
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 16-09-2026.
Shanling MTW200 Plus True Wireless Dynamic In-Ear Monitors IEM Ø10mm 32Ω 112dB 20Hz - 20kHz
Shanling MTW200 Plus : Front view
Shanling MTW200 Plus: Dynamic driver and acoustic chamber
Shanling's MTW200 Plus earphones each use a 10mm dynamic driver with a titanium-plated membrane and N50 magnetic circuit. The latter is coupled with a gold-plated acoustic chamber to protect it from interference that might be caused by Bluetooth components, ensuring quality sound reproduction devoid of any parasitic noise.
Shanling MTW200 Plus : Driver
Shanling MTW200 Plus : noise reduction
Shanling MTW200 Plus: Noise reduction and transparency mode
The MTW200 Plus earphones also feature noise reduction based on a mix of passive and active noise reduction technologies, allowing the earphones to adapt to the environment at all times, with a reduction of up to -43dB. Furthermore, you can also take advantage of a transparency mode, letting you enjoy your music while being aware of your surroundings.
Shanling MTW200 Plus: Bluetooth 5.3
As these are wireless earphones, it was vital for Shanling to select a Bluetooth chip that would allow us to make the most of their design quality. That's why they chose a Qualcomm Bluetooth 5.3 QCC3072 chip, which supports aptX Adaptive, aptX, AAC and SBC codecs, as well as Bluetooth Low Energy (BLE) for extended battery life.
Shanling MTW200 Plus :Bluetooth chip
Shanling MTW200 Plus : frequency response
Product typeTrue wireless In-Ear Monitor (IEM)
Drivers typeDynamic Ø13mm
DiaphragmTitanium
Sensitivity112±3dB
Impedance32Ω
Bluetooth version5.3
Supported Bluetooth protocolsaptX Adaptive, aptX, AAC, SBC
Bluetooth working distance10m (barrier-free open environment)
Phone callsYes
Earphones autonomy10h
Case autonomy42h
Réduction de bruit-43dB
Water resistance standardIPX7
Package1x Shanling MTW200 Plus
1x Charging case
1x USB-A to USB-C cable
5x Pairs of ear tips
Impedance (Ω)32
Efficiency / Sensitivity (dB)112.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessYes
Cable terminationWireless
Headphone / Earphone connectorWireless (Bluetooth)
Phone call featureYes
Noise reductionYes
3 reviews
Moyen
Tout est dit. En comparaison avec des Jabra Elite 5 que j'ai perdu, c'est moins bien.
Le boitier en alu est trop petit et paradoxalement trop lourd. Certes il se glisse très facilement dans une poche, un peu trop facilement même. Il est donc facile à perdre. L'alu et le système d'ouverture fait un peu trop "charnière", mais ça fonctionne bien.
L'écoute est moyenne (ni bien ni mauvaise, équilibrée).
Le confort est bof. Je n'aime pas ces écouteurs souvent trop petits, sans pour cela qu'ils doivent être proéminent. Il faut trouver le bon équilibre. Leur forme ne les rend pas si faciles à tenir dans 2 doigts quand on va vite et qu'on veut les manipuler.
Voilà, donc c'est bien mais sans plus.
This review has been posted for SHANLING MTW200 PLUS True Wireless Dynamic In-Ear Monitors IEM Ø10mm 32Ω 112dB 20Hz-20kHz
Ok pour un film, pas ok pour la musique
Autant pour les films ça passe, c'était mon objectif, le rendu en mode étendu est correct.
Autant pour la musique, ça ne me plait pas du tout : ça sature sur des notes de piano simples.
L'ergonomie ne permet pas de les garder dans mes oreilles quand je bouge un peu trop, malgré les embouts les plus petits, les contrôles sont approximatifs, et la réduction de bruit ne fait rien.
Très déçu à ce prix, il vaut mieux faire confiance à des marques plus grand public.
Snif ...
impressive
remarkably light, side independent (left can be right and vice versa, and once you take them out of the box, it resets the earbud put in the left socket as the main earbud), they sound great. Great bass extension while keeping great clarity. No buzzing sounds from bluetooth. Compared to quality wired iem, they sound just as good. The transparency/ANC modes while "available in the voice menu" do not work but who cares? Cherry on top, a beautiful case
With the MTW200 Plus, Shanling presents us with wireless in-ear earphones. The brand has opted for a dynamic 10mm driver with a titanium membrane,...
