SHOZY HIBIKI High Definition In-Ear Monitor 10mm Driver 18 Ohm
The Shozy Hibiki are in-ear headphones for high-definition listening while on the go or at home.
POINTS CLÉS :
  • Carbon design
  • Copper cable
  • 10mm drivers
  • 18 Ohm
  • Control panel + micro
Reference : 12351
49,90 €tax incl.
41,58 € tax excl.
SHOZY HIBIKI
High Definition
Shozy Hibiki IEM
A unique dynamic design
Shozy Hibiki IEMs have a unique design in their form: the combination of an ergonomic intra-channel design with carbon elements and a cable designed to ensure excellent audio performance and durability. In addition, Shozy brings another plus to the ergonomics of its IEMs by integrating a control box (volume +/-, play, pause) on the detachable cable, also integrating a MEMS microphone, compatible iOS and Android.
Shozy Hibiki IEM
Hibiki earphones incorporate high-quality components and design. Thus, its carbon faces are polished by hand. The cable, designed to bring resistance, incorporates copper conductors and a control box with micro MEMS and the 2 pins connector is also made of copper. Finally, the Shozy Hibiki incorporates dynamic drivers of 10mm for an impressive rendition.
Shozy Hibiki IEM
Ethos Black Copper Cable
Hibiki comes with an Ethos Black 26AWG cable composed of 4 braided wires each with a TPE jacket to isolate the conductors from any interference. Each wire incorporates pure copper conductors for excellent conductivity. Similarly, the contacts of the 2-pin connector of the cable are also made of pure copper.
Shozy Hibiki IEM
Shozy Hibiki écouteurs IEM
An interchangeable cable
These In-Ear monitor have a high quality connector to replace the cable provided by another model with this connector.
Shozy Hibiki Review by Headfonics
8/10
headfonics
Shozy Hibik unboxing by Porta_Fi
Technical Characteristics
DriverDynamic 10mm driver, proprietary design
Frequency response20-40kHz
Sensibility102dB SPL@1mW
Impedance18 Ohm @1kHz
THD<= 0.5% @1kHz
Connector2 pins
Cable4x pure copper conductor, TPE sleeve
The Shozy Hibiki are in-ear headphones for high-definition listening while on the go or at home. POINTS CLÉS : Carbon design Copper cable...
