SOFTEARS STUDIO4 In-Ear Monitors
New
With the Studio4, Softears presents in-ear monitors specially developed for professional use. Relying on 4 Balanced Armature drivers, these earphones offer the most neutral sound possible, making them ideal for monitoring or in a recording studio.
By buying this product you get 44 loyalty points
Reference : 20724
449,00 €tax incl.
374,17 € tax excl.
Softears Studio4 In-Ear Monitors IEM Balanced Armature 12 Ohm 123dB 5Hz-40kHz
Softears Studio4 : Front view
Softears Studio4: Professional earphones
The Studio4s have been designed primarily for professional use, using 4 balanced armature drivers to deliver the most neutral and flat sound reproduction possible, perfect for monitoring or use in recording studios. Furthermore, the Studio4s feature excellent acoustic isolation, effectively reducing external interference, making them ideal for outdoor use.
Softears Studio4 in a recording studio
Softears Studio4 : diameter reduction
Softears Studio4: Wearing comfort
The body of the Studio4 is made from 3D-printed medical-grade resin, which not only contributes to ultra-precise sound reproduction but also offers maximum wearing comfort. Compared with other Studio models, the Studio4s have a smaller external diameter and a reduced nozzle, making them both more comfortable and compatible with a wider range of eartips.
Softears Studio4: Extended compatibility
The frequency division architecture has been specially designed to match the output characteristics of professional audio interfaces as closely as possible. The result is earphones that are very easy to drive and have an almost straight impedance curve, enabling them to deliver very consistent performance, whatever the source in use.
Softears Studio4 : Cable supplied
Softears Studio4: High-quality cable
The Studio4 is supplied with a CIEM to 3.5mm jack cable made from OFC copper, guaranteeing high-quality signal transmission so you can get the most out of your earphones. Furthermore, an OFC copper extension cable is also included.
Product typeIn-ear monitors
Drivers4x Balanced armature drivers
Impedance12Ω @ 1kHz
Sensitivity123dB/Vrms @ 1kHz
Total harmonic distortion (THD)< 1% @ 1kHz
Frequency response5Hz-40kHz
Earphone connectorsCIEM 0.78mm 2 Pins
Cable terminationJack 3.5mm
Cable conductor materialOFC copper
Package1x Softears Studio4
1x Jack 3.5mm to CIEM cable
1x Jack 3.5 male to Jack 3.5mm female extension cable
1x Carrying bag
3x Pairs of ear tips
Impedance (Ω)12
Efficiency / Sensitivity (dB)123.0
WirelessNo
Phone call featureNo
Noise reductionNo
SOFTEARS STUDIO4 In-Ear Monitors IEM Balanced Armature 12 Ohm 123dB 5Hz-40kHz
With the Studio4, Softears presents in-ear monitors specially developed for professional use. Relying on 4 Balanced Armature drivers, these...
