TANCHJIM BUNNY TYPE-C Dynamic In-Ear Monitor
With the Bunny, Tanchjim offers in-ear earphones that are as affordable as they are qualitative. They feature a titanium-plated driver coupled with a double acoustic cavity specially designed to promote low-frequency vibration. The result is a sound reproduction with rich bass and precise highs, offering a wide soundstage.
Reference : 20419
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 24-04-2025.
Tanchjim Bunny Type-C Dynamic In-Ear Monitor IEM DSP 30Ω 123dB 8Hz-48kHz
Tanchjim Bunny Type-C : Front view
Furthermore, the USB-C version of the Bunny also integrates a 24bit DAC, an amplifier stage and a DSP, opening up the possibility of customizing sound rendering thanks to a 5-band equalizer available via the Tanchjin app.
Tanchjim Bunny Type-C: Dynamic driver
Tanchjim's Bunny earphones feature dynamic drivers with titanium-plated PET (polyethylene terephthalate) diaphragms and flexible suspension, delivering rich bass, clear vocals and a wide soundstage.
These drivers are complemented by a double acoustic chamber, offering more precise control over bass and midrange, while providing a harmonic distortion rate of 0.05% at 94dB.
Tanchjim Bunny Type-C : Driver
Tanchjim Bunny Type-C : acoustic cavity
Tanchjim Bunny Type-C: Labyrinth structure of the acoustic cavity
Bunny earphones benefit from a labyrinth structure of their acoustic cavities, offering even more resonance to low frequencies for deeper, more dynamic sound reproduction.
Tanchjim Bunny Type-C: Optimized internal cavity
The Bunny's internal cavity has been developed to minimize high-frequency absorption and sound dispersion, resulting in a clearer, more extended high-frequency response thanks to the improved linearity of the sound waves.
Tanchjim Bunny Type-C : internal cavity
Tanchjim Bunny Type-C : earphones and cable
Tanchjim Bunny Type-C: Silver-plated OFC copper cable
Bunny is supplied with a silver-plated OFC copper cable to ensure noise-free data transmission. A flexible transparent sheath encloses the cable, making it difficult to entangle.
Tanchjim Bunny Type-C: DAC and DSP
The USB-C version of the Bunny also incorporates a two-chip 24bit DAC supporting a sampling rate of up to 96kHz. This version also includes a high-performance operational amplifier, as well as a DSP for furthermore precise control over the final sound output.
Tanchjim Bunny Type-C :DSP
Tanchjim Bunny Type-C: 5-band equalizer
Thanks to the Bunny's built-in DSP, you can use the Tanchjim application available here to shape the sound of your earphones to your taste. To do this, you have access to 4 equalization presets and a 5-band equalizer, with the option of saving and sharing your sound profiles with other users.
Tanchjim Bunny Type-C: Frequency response
Tanchjim Bunny Type-C : frequency response
Product typeIn-ear monitors (IEM)
Speakers typeDynamic
Speakers technologieDMT4 Ultra
DiaphragmTitanium-plated PET (Polyethylene terephthalate)
Sensibility123dB
Impedance30Ω
Total harmonic distortion (THD)0.05% @ 1kHz 94dB
Frequency response8Hz-48kHz
Conductor materialSilver-plated OFC copper
Cable structureLitz wires
Connector2 pins 0.78mm
ColorSilver
Package1x Tanchjim Bunny Type-C
1x USB-C to 2-pin 0.78mm connector cable
1x Carrying pouch
ColorSilver
Impedance (Ω)30
Efficiency / Sensitivity (dB)123.0
Lowest frequency (Hz)8
Highest frequency (Hz)48000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
TANCHJIM BUNNY TYPE-C Dynamic In-Ear Monitor IEM 30 Ohm 123dB 8Hz-48kHz
With the Bunny, Tanchjim offers in-ear earphones that are as affordable as they are qualitative. They feature a titanium-plated driver coupled with...
