TANCHJIM KARA In-Ear Monitors IEM Hybrid Dynamic + Balanced Armature 27 Ohm 115dB 7Hz-40kHz
Tanchjim Kara in-ear earphones use a Sonion 2389D Balanced Armature driver imported from Denmark for midrange and high frequencies, and a second custom Balanced Armature driver for ultra-high frequencies. Low frequencies are handled by a dynamic driver with special 9mm voice coil and composite diaphragm. This results in reduced distortion and a wider dynamic range, offering a more natural sound.
Reference : 18082
169,00 €tax incl.
140,83 € tax excl.
Shipping date: 22-04-2025.
TANCHJIM KARA
TANCHJIM KARA Écouteurs Intra-Auriculaires IEM
TANCHJIM KARA
Highly transparent medical grade resin
Tanchjim Kara use medical-grade resin to provide a pleasant feel and great durability. Thanks to high-precision DLP3D printing technology and an ergonomic design, the earphones adapt more precisely to the contours of the ear, giving you a comfortable, immersive listening experience..
TANCHJIM KARA Écouteurs IEM
High-quality wiring with Litz 6N wires
Supplied as standard, the CIEM 0.78mm to detachable 3.5mm headphone jack cable is made of pure OFC 6N copper, silver-plated. The use of Litz wire makes the cable flexible and antioxidant. What's more, the braiding and wire diameter are precisely adjusted. The result is a balanced, transparent sound.
Technical specifications
Product typeIn-ear monitors (IEM)
Type of drivers1 DD + 4 BA:
Hybrids Dynamic
Balanced Armature
Earphone connectors
CIEM 0.78mm 2 pins gold plated
Cable connectorJack 3.5mm gold plated
Frequency response7Hz - 40kHz
Impedance27Ω (±10%)
Distorsion< 0.8% @ 1kHz
Sensitivity115dB/Vrms
Cable length1.25m
Conductor of the cableSilver-plated OFC copper Litz wire
ColorSilver
Package1* Pair of Tanchjim Kara earphones
1* White storage pouch
1* CIEM 0.78mm 2 pins to Jack 3.5mm cable 1.25m
6* Pairs of eartips (S / M / L)
ColorSilver
Impedance (Ω)27
Efficiency / Sensitivity (dB)115.0
Lowest frequency (Hz)7
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
Tanchjim Kara in-ear earphones use a Sonion 2389D Balanced Armature driver imported from Denmark for midrange and high frequencies, and a second...
