The Tanchjim Mino are high-performance, affordable Bluetooth wireless in-ear monitors. Each earphone features a 10mm dynamic driver for rich, lively sound reproduction. The earphones come with a charging case for extended battery life and easy transport. What's more, the Tanchjim Mino feature effective Active Noise Cancellation (ANC) technology.
Tanchjim Mino earphones feature active noise cancellation (ANC) technology based on deep learning, enabling noise reduction down to -45dB. As a result, the majority of surrounding noise can be eliminated by activating this feature, for perfect immersion in your music.
The Tanchjim Mino feature a dynamic 10mm driver using a powerful magnetic circuit. Each driver is equipped with a beryllium-plated dome and PU suspension to extend the headphones' dynamic range, while greatly reducing distortion (non-linear distortion below 0.1%) and promoting a defined soundstage.
By activating the Transparency mode of the Tanchjim Mino earphones, you can enjoy your music while remaining aware of your surroundings. Ideal when you're on the move and need to keep an eye on the outside world.
The Tanchjim Mino are professionally tuned for detailed highs, smooth mids and immersive lows to match the brand's defined response curve.
One of the Tanchjim Mino earphones features a dual microphone for sound filtering. It also incorporates a wind detection system. So you can make calls and enjoy crystal-clear exchanges with the person you're talking to, thanks to ENC ambient noise cancellation technology.
With the noise-cancellation mode activated, each earphone has a comfortable battery life of 5 hours per charge. Added to this is the charging box, which recharges the Tanchjim Mino for up to 31 hours. In Normal listening mode, this autonomy increases to 6h per earphone, and is extended to 37h with the charging box.
Thanks to the integrated magnetic switch, Tanchjim Mino headphones automatically reconnect to your previously paired smartphone or source device as soon as the case cover is opened.
Tanchjim provides a free mobile app to access additional functions, including sound profiles, equalizer, touch control management and more. This app is available on Android via an apk or downloadable for iOS devices directly from the App Store.
With a delay of just 0.045 seconds, the Tanchjim Mino are particularly responsive. So they're also ideal for gamers requiring latency-free sound.
Thanks to their IPX4 rating, Tanchjim Mino earphones are waterproof and dustproof. So you can use them even on a rainy day, without risk of damage.
Make sure the earphones are dry when stored in the charging box.
Bluetooth version 5.3 ensures a fast, stable connection, thanks in particular to optimized anti-interference technology.
Tancjim Mino features an intelligent touch control system. So you can control your music playback or answer a call simply by touching your earphones:
Thanks to a capacitive sensor on the earpieces, your music stops automatically when an earpiece is removed from your ear. Likewise, playback resumes automatically as soon as the earpiece is reinserted in your ear.
Product type | In-ear monitors |
Connection mode | Bluetooth 5.3 |
Frequency response | 20Hz - 20kHz |
Max range | 15m |
Drivers | Dynamic Ø10mm |
Drivers materials | Beryllium-coated dome PU surround |
Impedance | 32Ω ±10% @ 1kHz |
Wired charging interface | USB-C |
Wired charge voltage / current | 5V 1A |
Codecs Bluetooth supportés | AAC, SBC |
Battery life | 5h + 26h |
Battery capacity | Earphones: 35mAh 3.7V 0.129Wh Charging case: 380mAh 3.7V 1.406Wh |
Color | White |
Package | 1x Tanchjim Mino earphones pair 1x Charging case 1x Charging cable 3x Eartips pairs (S/M/L) |
Color | White |
Impedance (Ω) | 32 |
Efficiency / Sensitivity (dB) | N/A |
Wireless | Yes |
Cable termination | Wireless |
Headphone / Earphone connector | Wireless (Bluetooth) |
Phone call feature | Yes |
Noise reduction | Yes |
