TANCHJIM ORIGIN In-Ear Monitors
With the Origin, Tanchjim unveils high-quality in-ear monitors designed to deliver faithful, dynamic sound. The design of this model has been meticulously thought through, from the driver to the internal structure of the IEMs, to ensure exceptional sound quality.
Reference : 18812
249,00 €tax incl.
207,50 € tax excl.
Shipping date: 23-04-2025.
Tanchjim Origin In-Ear Monitors IEM Dynamic Ø10mm 16 Ohm 126dB 2Hz - 48kHz
Tanchjim Origin: In-ear monitors
Tanchjim Origin: Key features
Tanchjim Origin: Internal view
Five generations of products for a model of excellence
Tanchjim Origin IEMs use a DMT5 10mm dynamic driver. This high-end model is combined with a double magnetic cavity, ensuring high magnetic flux, low distortion, high dynamics and high efficiency. Harmonic distortion is measured at less than 0.056% (at 1kHz, 94dB), helping to deliver beautiful tonal quality, a wider soundstage and perfect separation.
Tanchjim Origin: A composite membrane that's both rigid and flexible
The membrane specially designed for the DMT5 magnetic circuit and the acoustic cavities of the Origin monitors, combined with an optimized internal design, ensure that these IEM deliver precise, rich reproduction with beautiful dynamics.
Tanchjim Origin: Wave guide
Tanchjim Origin: Low-distortion waveguide
Waveguide surfaces are optimized to improve modal distribution efficiency and high-frequency acoustic energy transfer. The result is better overall sound quality.
Tanchjim Origin: Interchangeable acoustic tubes
Tanchjim Origin acoustic tubes can be easily unscrewed and replaced by the other models supplied. In addition to the Standard (S) tube, Dynamic (D) and Light (L) models are supplied. The internal geometry of the three models is slightly different, allowing the Tanchjim Origin's sound reproduction to be adapted.
Tanchjim Origin: Optimized ventilation
Tanchjim Origin: Optimized ventilation system
The combination of the rear cavity structure and the ventilation grille enhances the dynamic range of DMT5 loudspeakers.
Tanchjim Origin: Double composite cover
The Tanchjim Origin IEMs feature a double cover to protect the inside of the headphones. A stainless steel grille retains large impurities, while a DWR acoustic fabric filters out fine particles while remaining waterproof.
Tanchjim Origin: An ulra-linear response
The Tanchjim Origin benefit from an ultra-linear frequency response, the result of numerous measurements and tests. The result is a faithful, transparent sound that perfectly respects your music.
Tanchjim Origin: Frequency response measurement
Tanchjim Origin: A sober, modern design
Tanchjim Origin: A refined, luxurious design
The Tanchjim Origin have a sober, modern design, combining soft curves with a 3D-engraved logo. The body of these headphones is made of 304 stainless steel, offering perfect resistance to oxidation for enhanced durability.
Tanchjim Origin: High-quality cable
The cable supplied with the Tanchjim Origin uses OFC 6N copper conductors, ensuring excellent conductivity for perfect signal transmission. The connectors are gold-plated.
Tanchjim Origin: Cable with OFC copper conductors
Tanchjim Origin: T-APB tips
The T-APB eartips supplied with Tanchjim Origin earphones are designed to provide excellent wearing comfort while limiting hearing fatigue caused by differences in internal and external acoustic pressure. What's more, these models also deliver high-quality sound reproduction. Three sizes are supplied (S/M/L).
Tanchjim Origin: PVC storage case
A PVC and leather storage case provides effective protection for your Tanchjim Origin earphones when not in use.
Tanchjim Origin: PVC and leather storage case
Package
Tanchjim Origin : Package
Product typeIn-ear monitors
Driver typeDynamic, DMT5
Dual magnetic circuit
THD< 0.056% @ 1kHz, 94dB
Impedance16Ω ±5%
Sensitivity126dB/Vrms
Frequency response2Hz - 48kHz
Cable conductorsSilver-plated OFC copper
Cable length1.25m
Cable connectors2x CIEM 0.78mm
1x Jack 3.5mm
Cable connectors platingOr
Package1x Pair of Tanchjim Origin earphones
1x Cable
3x Pairs of acoustic tubes
6x Pairs of eartips
1x PVC storage case
ColorSilver
Impedance (Ω)16
Efficiency / Sensitivity (dB)126.0
Lowest frequency (Hz)2000
Highest frequency (Hz)48000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
TANCHJIM ORIGIN In-Ear Monitors IEM Dynamic Ø10mm 16 Ohm 126dB 2Hz - 48kHz
With the Origin, Tanchjim unveils high-quality in-ear monitors designed to deliver faithful, dynamic sound. The design of this model has been...
