TANCHJIM OXYGEN Dynamic IEM In-Ear Monitors Ø9.2mm 32 Ohm 110dB 10Hz-40kHz
TANCHJIM OXYGEN earphones have been designed to provide a qualitative sound quality, they are high-end earphones. The driver uses a dual-chamber, dual-dynamic brake carbon nanotube. The affixed adjustments allow a rich and detailed sound rendering. The internal cable made of high purity gold and silver alloy allows optimal conductivity and very pure sound.
By buying this product you get 22 loyalty points
Reference : 17670
225,00 €tax incl.
187,50 € tax excl.
Shipping date: 22-04-2025.
TANCHJIM OXYGEN
Dynamic IEM In-Ear Monitors Ø9.2mm 32 Ohm 110dB 10Hz-40kHzTANCHJIM OXYGEN Écouteurs Intra-Auriculaires IEM Dynamique 9.2mm 32 Ohm 110dB 10Hz-40kHz
The Tanchjim Oxygen in-ear monitors have been designed to provide quality sound rendering. It is a high-end model providing excellent audio performance. The driver uses a carbon nanotube with dual chamber and dual dynamic brake. The applied adjustments allow a rich and detailed sound rendering. The internal wiring is made of high purity gold and silver alloy for optimal conductivity and a very pure sound.
Design and elegance
The outer shell is hand polished and each pair is unique. The front shell is made up of a shiny, sober and elegant pattern. The material used for the shell is used in luxury products and is scratch resistant.
Product typeIn-Ear Monitors (IEM)
Speaker typeØ9.2mm dynamic drivers (carbon nanotube)
Headphone connectors
0.78mm 2PIN
Cable connector3.5mm Jack gold plated
Frequency response10Hz - 40kHz
Impedance32Ω
Sensitivity110dB
Cable length1.2m
ColorSilver
Package1* Pair of Tanchjim Oxygen IEM
1* Storage pouch
1* 0.78mm 2 Pin to 3.5mm Jack Cable
6* pairs of ear tips (S / M / L)
ColorSilver
Impedance (Ω)32
Efficiency / Sensitivity (dB)110
Lowest frequency (Hz)10
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
TANCHJIM OXYGEN earphones have been designed to provide a qualitative sound quality, they are high-end earphones.  The driver uses a...
