TANCHJIM ZERO Dynamic In-Ear Monitor IEM with Microphone Ø10mm 118dB 32 Ohm 7Hz-50kHz
These Tanchjim Zero in-ear headphones benefit from a very good quality of design and sound reproduction at an exceptionally affordable price. Each IEM embeds a 10mm diameter dynamic speaker. The composite of the diaphragm is the same material as on high-end headphones, the dome is plated in bellyrium, which allows these headphones to have a wide bandwidth. The DMT4 dynamic driver gives this pair of headphones great responsiveness as well as delicate high frequencies and deep bass.
Reference : 17666
16,90 €tax incl.
14,08 € tax excl.
TANCHJIM ZERO
TANCHJIM ZERO Écouteurs Intra-Auriculaires IEM Dynamiques 10mm avec Microphone 118dB 32 Ohm 7Hz-50kHz
These Tanchjim ZEro in-ear monitor benefit from a very good quality of design and sound reproduction at an exceptionally affordable price. Each IEM embeds a 10mm diameter dynamic driver. The composite of the diaphragm is the same material as on high-end headphones, the dome is plated in bellyrium, which allows these headphones to have a wide bandwidth. The DMT4 dynamic driver gives this pair of headphones great responsiveness as well as delicate high frequencies and deep bass.
Finally, this model is equipped on its USB-C cable with a small control box incorporating a microphone, thus making it easy to answer calls.
High quality cable with integrated microphone
The conductor of the Tanchjim Zero cable is made of 4 silver-plated OFC copper conductors with kevlar and anti-oxidation treatment. However, the cable remains flexible.
The built-in microphone also features Play/Pause and Previous/Next functions.
specification
Product typeIn-ears monitors (IEM)
Speakers type10mm Dynamic
Speakers technologieDMT4
MembraneFlexible ultra-fine fiber suspension + beryllium-plated dome
Sensibility118dB/Vrms @ 1kHz
Impedance32Ω ±10% @ 1kHz
THD< 0.5% @ 1kHz, 94dB SPL
Frequency response7Hz-50kHz
Control / Microphone
Cable length125cm
Conductor materialSilver plated OFC copper
Cable structureAnti-oxidation Litz wires
ConnectorUSB-C
ColorSilver
ColorTransparent
Impedance (Ω)32
Efficiency / Sensitivity (dB)118.0
Lowest frequency (Hz)7
Highest frequency (Hz)50000
WirelessNo
Excellent
très bons écouteurs que j'utilise sur iphone. pour du classique et du jazz que je n'écoute pas très fort. Le son est hifi incontestablement avec de très bonnes basses.
belles sonorités avec une bonne précision et dynamique. Les écouteurs son légers car en plastique, mais la tenus est plus facile, le fil pourrait être mieux mais pour le prix ... Super Rapport qualité prix. Pour le son, c'est presque aussi bien que le FIIO FD11.
This review has been posted for TANCHJIM ZERO Dynamic In-Ear Monitor IEM with Microphone Ø10mm 118dB 32 Ohm 7Hz-50kHz
These Tanchjim Zero in-ear headphones benefit from a very good quality of design and sound reproduction at an exceptionally...
