THIEAUDIO HYPE 10 In-Ear Monitors
THIEAUDIO Hype 10 (HYPE for Hybrid Performance) are a pair of high-end in-ear monitors from the brand's Hype series. These earphones use 10 Balanced Armature drivers for treble, midrange and bass, as well as IMPACT² technology consisting of 2 x 10mm diaphragms for infrabass.
By buying this product you get 89 loyalty points
Reference : 19546
899,00 €tax incl.
749,17 € tax excl.
Shipping date: 25-04-2025.
Thieaudio Hype 10 In-Ear Monitors IEM Dynamic 18Ω 105dB 10Hz-40kHz
THIEAUDIO HYPE 10 picture
Thieaudio Hype 10 (HyPe for Hybrid Performance) are a pair of high-end in-ear monitors from the brand's Hype series. These earphones use 10 Balanced Armature drivers for treble, midrange and bass, as well as IMPACT² technology consisting of 2 x 10mm diaphragms for infrabass. This configuration enables them to achieve an extended frequency response (10Hz-40kHz) and, consequently, a wide soundstage rich in detail, with deep, immersive bass. THIEAUDIO's Hype 10 is of course equipped with equalization to achieve the brand's signature sound reproduction so appreciated by its fans. It also features an audiophile cable with silver-plated OCC pure copper conductors.
Thieaudio Hype 10: a 10-driver hybrid design
The Hype 10 structure incorporates two Knowles SWFK 31736 ultra-tweeters, two Sonion E50DT midrange drivers and two Sonion 28UAP woofers combined with 4 independent acoustic chambers for high-fidelity sound reproduction. Knowles SWFK 31736 tweeters were chosen for their high-frequency extension up to 40kHz and their compatibility with the Sonion E50DT. This combination ensures perfect cohesion in the transition between treble and midrange, for a highly detailed level of rendering. As for the 28UAP drivers already present on the brand's signature series, they integrate perfectly with IMPACT² technology to enhance the infrabass.
Thieaudio Hype 10: IMPACT² technology for immersive infrabass
IMPACT² technology, consisting of 2 composite diaphragms of 10mm each, positioned according to an isobaric design, considerably enhances the texture of bass resounding at 300Hz, while preserving a beautiful tonality.
Thieaudio Hype 10: a balanced response curve
The Hype 10's flat midrange between 300Hz and 1kHz brings out the natural tonality of instruments and voices. The highs have been equalized to match the lows, for a clear, richly detailed sound reproduction.
THIEAUDIO HYPE 10 response curve
Thieaudio Hype 10: an audiophile cable
This pair of in-ear monitors comes with a 1.2m cable featuring a 3.5mm jack and 0.78mm CIEM tips, as well as a variety of silicone and foam eartips. The cable conductors are made of silver-plated OCC pure copper for enhanced signal conductivity.
Product typeIn-ear monitors
Structure2DD+10BA
Drivers2x Knowles SWFK 31736 ultra-tweeter
2x Sonion E50DT (midrange)
2x Sonion 28UAP (bass)
2x 10mm dynamic drivers (IMPACT²)
4x Acoustic chamber
Sensitivity105dB/Vrms@1KHz
Impedance18Ω @1KHz
Frequency response10Hz-40kHz
Pack1x Pair of THIEAUDIO HYPE 10 IEMs
1x Cable with CIEM 0.78mm connectors to interchangeable termination
1x 3.5mm jack termination
1x Balanced jack termination 2.5mm
1x Balanced jack termination 4.4mm
3x Pairs of foam tips (S, M, L)
3x Pairs of silicone tips (S, M, L)
1x Storage pouch
Impedance (Ω)18
Efficiency / Sensitivity (dB)105.0
Lowest frequency (Hz)10
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 2.5mm
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
THIEAUDIO HYPE 10 In-Ear Monitors IEM Dynamic 18Ω 105dB 10Hz-40kHz
THIEAUDIO Hype 10 (HYPE for Hybrid Performance) are a pair of high-end in-ear monitors from the brand's Hype series. These earphones use 10...
