THIEAUDIO HYPE 2 In-Ear Monitors IEM Dynamic 25Ω 108dB 20-20kHz Purple
Thieaudio's HYPE 2 (HYPE for Hybrid Performance) in-ear monitors are an innovative pair of earphones that combine technical and musical excellence. These in-ear monitors feature 2 Balanced Armature Sonion drivers for treble and midrange, and 2 dynamic 10mm drivers for bass. HYPE 2 represent an excellent entry into Thieaudio's top-of-the-range earphone series.
By buying this product you get 31 loyalty points
Reference : 18156
319,00 €tax incl.
265,83 € tax excl.
Shipping date: 16-04-2025.
THIEAUDIO HYPE 2 ZICAO
Thieaudio's HYPE 2 (HYPE for Hybrid Performance) in-ear monitors are an innovative pair of earphones that combine technical and musical excellence. These in-ear monitors feature 2 Balanced Armature Sonion drivers for treble and midrange, and 2 dynamic 10mm drivers for bass. The HYPE 2's design also incorporates Thieaudio's own balanced tone controls. All in all, these in-ear monitors offer a listening experience with deep bass, flat midrange and detailed, rich highs that are controlled to avoid unwanted peaks. HYPE 2 represent an excellent entry into Thieaudio's high-end headphone series.
Two 10mm dynamic drivers for powerful bass thanks to IMPACT² technology
Thieaudio has chosen to incorporate two 10mm composite dynamic drivers to handle the low frequencies in the HYPE 2. These two drivers use IMPACT² technology, which consists in arranging the two drivers in an Isobaric design. This greatly enhances the power and texture of the bass, while preserving a beautiful tonality.
Two Sonion Balanced Armature drivers
For midrange and treble, Thiaudio has selected two Sonion Balanced Armature drivers: the P2356HF/4 for midrange and the E25ST001/D for treble. The P2356HF/4 delivers better midrange clarity and resolution than most of its range on the market, as well as reduced THD, while the P2356HF/4 offers smooth, coherent extended highs. As with the electrostatic speakers (EST), the P2356HF/4 delivers superb performance in the upper treble range.
Balanced Tuning
Thieaudio wanted to give these earphones a professional tonal rendering. Bass is tightened to 200Hz, allowing the midrange to remain neutral, while treble is controlled to be very rich while avoiding undesirable peaks. All in all, users already familiar with the brand will find Thieaudio's much-appreciated signature sound in the HYPE 2.
Good looking and useful accessories
The shell material is made from 3D-printed medical resin, a durable and perfectly hypoallergenic material. Each earpiece is uniquely designed for an aesthetically pleasing look. In addition, a 1.2m long cable with 3.5mm jack and 0.78mm CIEM plugs, as well as a variety of silicone and foam ear-tips, are supplied with this pair of in-ear earphones.
Product typeIn-ear monitors (IEM)
Drivers2x 10mm dynamic drivers
2x Sonion Balanced Armature drivers
Impedance25Ω
Sensibility108dB
Frequency response20Hz-20kHz
Cable length1.2m
Cable connector3.5mm jack
Earphones connectorsCIEM 0.78mm
ColorPurple
Package1x THIEAUDIO HYPE 2 ZICAO in-ear monitors
1x 1.2m cable with 0.78mm CIEM connectors and 3.5mm jack termination
ColorViolet
Impedance (Ω)25
Efficiency / Sensitivity (dB)108
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
Thieaudio's HYPE 2 (HYPE for Hybrid Performance) in-ear monitors are an innovative pair of earphones that combine technical and musical...
