THIEAUDIO HYPE 4 In-Ear Monitors IEM White
Thieaudio presents the latest addition to its HYPE (for Hybrid Performance) series of in-ear headphones: the HYPE 4. With this new model, Thieaudio continues to offer an innovative pair of headphones that combine technical and musical excellence. In fact, the HYPE 4 feature 6 drivers for optimum coverage of the entire frequency range. The whole is coupled with the brand's characteristic equalization, much appreciated by its fans.
By buying this product you get 39 loyalty points
Reference : 19262
399,00 €tax incl.
332,50 € tax excl.
Shipping date: 23-04-2025.
THIEAUDIO Hype 4 In-Ear Monitors IEM Dynamic 17Ω 105dB 10-22kHz White
THIEAUDIO Hype 4 In-Ear Monitors IEM Dynamic 17Ω 105dB 10-22kHz : front view
Thieaudio presents the latest addition to its HYPE (for Hybrid Performance) series of in-ear monitors : the HYPE 4. With this new model, Thieaudio continues to offer an innovative pair of headphones that combine technical and musical excellence. In fact, the HYPE 4 feature 6 drivers for optimum coverage of the entire frequency range. The whole is coupled with the brand's characteristic equalization, much appreciated by its fans.
Thieaudio HYPE 4: 6-drivers configuration
Like their predecessors, the HYPE 2, these earphones feature Thieaudio's IMPACT² technology. This technology consists in the integration of two 10mm composite diaphragms dynamic drivers arranged in an isobaric design. These two dynamic drivers are responsible for handling low frequencies, ensuring powerful, textured bass while preserving a beautiful tonality. However, unlike their ancestors, HYPE 4 continue down the path of audio spectrum breakdown, entrusting mids and high frequencies to four specialized drivers. The midrange frequency range is covered by two Balanced Armature drivers from Sonion's 26A series. This layout ensures a good tonal balance, offering a very neutral midrange with very little treble, and an excellent output power-to-total harmonic distortion ratio. The frequency range for the treble is entrusted to two Soinion E50 "Hummingbird" series Balanced Armature ultra-tweeter drivers, offering a high-frequency extension rivaling the Planar Magnetic drivers, while guaranteeing a very low level of harmonic distortion.
Thieaudio HYPE 4: a distinctive equalization
Thieaudio has taken up the equalization blueprint of its Monarch MKII, Clairevoyance and Oracle models, which have made the brand so successful. As a result, the HYPE 4 earphones deliver a beautiful sub-bass presence that fades out precisely at 200Hz, giving way to an absolutely neutral midrange that precedes a more pronounced presence that peaks at 3kHz, before slowly dropping off to 20kHz.
THIEAUDIO Hype 4 In-Ear Monitors IEM Dynamic 17Ω 105dB 10-22kHz : EQ
Thieaudio HYPE 4: a custom-made cable
HYPE 4 earphones also include an OCC silver-plated cable. This material improvement over the firm's previous generation of cables results in a clearer, more refined sound than before.
THIEAUDIO Hype 4 In-Ear Monitors IEM Dynamic 17Ω 105dB 10-22kHz : Cable with 0.78mm CIEM connectors and 3.5mm jack termination
Product typeIn-ear monitors (IEM)
Hauts-parleurs2x 10mm dynamic drivers
2x Sonion E50 Balanced Armature drivers
2x Sonion 26A Balanced Armature drivers
Impedance17 Ohm
Sensibility105dB (±1dB) @1kHz
Frequency response10Hz - 22kHz
Cable connectorJack 3.5mm
Earphones connectorsCIEM 0.78mm
ColorWhite
Package1x White THIEAUDIO HYPE 4 in-ear monitors
1x Cable with 0.78mm CIEM connectors and 3.5mm jack termination
ColorWhite
Impedance (Ω)17
Efficiency / Sensitivity (dB)105.0
Lowest frequency (Hz)10
Highest frequency (Hz)22000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
THIEAUDIO HYPE 4 In-Ear Monitors IEM Dynamic 17 Ohm 105dB 10-22kHz White
Thieaudio presents the latest addition to its HYPE (for Hybrid Performance) series of in-ear headphones: the HYPE 4. With this new model, Thieaudio...
