THIEAUDIO LEGACY 2 Dynamic Beryllium In-Ear Monitor IEM 32 Ohm 108dB 20Hz-20kHz
The LEGACY Series draws on THIEAUDIO's engineering capabilities to merge the latest speaker innovations, creating a range of high-performance hybrid in-ear monitors
Reference : 16726
115,00 €tax incl.
95,83 € tax excl.
Shipping date: 25-04-2025.
THIEAUDIO legacy 2
Beryllium IEM Dynamic In-Ear Headphones
Thieaudio Legacy 2 Écouteurs intra-auriculaires IEM dynamiques
The LEGACY Series draws on THIEAUDIO's engineering capabilities to merge the latest speaker innovations, creating a range of high-performance hybrid in-ear monitors. Aimed at audiophiles and discerning music lovers, these headphones redefine the qualities that make up high-fidelity audio to present a unique combination of comfortable fit and excellent technical performance.
With each model in the Legacy Series, Thieaudio hopes to reveal a refreshing new perspective on the everyday listening experience, extending even deeper into the music.
When legendary drivers meet
Bass performance has always been of particular importance to Thieaudio, which is why this LEGACY 2, with its incorporation of dynamic woofers, has been launched. Their team has come a long way in the development of dynamic drivers, and offers a new closed 10mm beryllium driver. Using stronger internal magnets and a new acoustic enclosure design, they have taken this driver to its full potential, producing low frequency responses beyond expectation.
For the choice of mid-high range driver, Thieaudio decided to use the legendary and proven Knowles ED29689 balanced armature driver. The ED29689 is particularly interesting because it has a completely neutral midrange response, a precise transition between midrange and high frequencies and a very resolute reproduction of the highs.
Technical specifications
Type of productIn-Ear Earphones (IEM)
Type of speakersKnowles 29689 + 10mm Beryllium
Headphone connectors
0.78mm 2PIN
Cable connectorJack 3.5mm
Impedance32Ω
Sensitivity108dB/Nrms
Noise insulation26dB
Cable length1.2m
ColorBlue
ColorBlue
Impedance (Ω)32
Efficiency / Sensitivity (dB)108
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
The LEGACY Series draws on THIEAUDIO's engineering capabilities to merge the latest speaker innovations, creating a range of high-performance...
