THIEAUDIO MONARCH MKIII In-Ear Monitor IEM Dynamic Electrostatic 20 Ohm 99dB 20Hz-40kHz
With updated and optimised drivers and adjustments, as well as significantly improved ergonomics, Thieaudio Monarch MKIII in-ear earphones deliver the exceptional performance of the MKII version with enhanced technical features and comfort. These IEMs are capable of delivering incredibly accurate and rich sound reproduction, so you can enjoy your music to the full, whether you're on the move or at home.
By buying this product you get 119 loyalty points
Reference : 18071
1 199,00 €tax incl.
999,17 € tax excl.
Shipping date: 22-04-2025.
Thieaudio Monarch MKIII In-Ear Monitor IEM Dynamic Electrostatic 20 Ohm 99dB 20Hz-40kHz
Thieaudio Monarch MKIII highlights:
IMPACT2
Thieaudio's latest innovation in custom audio with a powerful subwoofer solution using isobaric design and composite diaphragms.
Improved treble
Monarch MKIIIs are now equipped with Sonion electrostatic speakers for extended high frequencies, resulting in a more accurate sound and a wider soundstage.
A balanced sound signature
Monarch MKIIIs maintain tonal excellence comparable to that of studio monitors with a clean, natural and detailed sound, while offering a gain in bass depth.
Deep bass
The addition of a 10mm subwoofer in the IMPACT2 enhances bass power and texture without compromising tonal integrity, offering improved bass quality for an immersive audio experience.
IMPACT2: Thieaudio's latest technological innovation
The IMPACT2 is a completely new subwoofer solution featuring two 10mm composite diaphragm drivers in an isobaric arrangement. The addition of a second driver dramatically improves the depth and quality of the bass, while the internal design of the isobaric chamber maintains constant frequency and pressure. So you can enjoy powerful bass without sacrificing tonal integrity.
Treble of incredible finesse
The Monarch MKIIIs have been updated with Sonion's latest electrostatic transducers (ESTs) and perfectly tuned to exploit the full potential of these drivers. Thanks to a new Sonion tuning strategy, the highest frequencies, from 15kHz to 20kHz, have been increased for a more complete extension of the treble. Compared with their predecessors, the Monarch MKIIIs offer a wider soundstage and an overall improvement in perceived resolution.
Perfect tonal balance
Thieaudio's commitment to perfect tonal balance is at the heart of these Monarch MKIIIs. They retain a sound signature worthy of studio monitors, with a targeted impact on bass for a clean, natural and detailed sound reproduction. Designed with a true 4-way crossover with 9 separate passive components, the Monarch MKIII remain true to their sonic heritage. Thanks to IMPACT2, the bass is more punchy, but the midrange from 200Hz to 800Hz retains its neutrality.
In addition, compared with their predecessors, the midrange of the Monarch MKIII has been revised with a new tuning strategy, better separating the reproduction ranges of the different drivers to maximise output while minimising total harmonic distortion. The treble has also been slightly readjusted to offer greater overall coherence but also greater precision. This slight tonal change is better matched by the renewed response of the ultra-highs, offering a sharper response.
A medical-grade resin body
Each Monarch MKIII is individually handcrafted by the brand's engineers and technicians. The body of the IEMs is 3D printed from medical-grade resin, which is skin-friendly and durable. In addition, each Monarch MKIII faceplate is individually decorated, offering unique designs for each pair.
Interchangeable high-quality cable
Monarch MKIIIs are supplied with the latest Thieaudio cable. This is made of 0.33mm² (22AWG) OCC 6N copper wire, silver-plated. This improvement in the cable's materials brings a little more clarity and refinement than the previous generation. In addition, interchangeable connectors in Jack 3.5mm, Jack 4.4mm balanced and Jack 2.5mm balanced formats are provided, enabling Monarch MKIIIs to be easily associated with any device. The cable itself is detachable, so can be replaced by a different model if required.
Complete package
Monarch MKIIIs come as part of a complete package, with a number of practical and useful accessories:
  • Monarch MKIII in-ear monitors
  • A braided cable with 6N OCC copper conductors
  • A single-ended Jack 3.5mm connector
  • A balanced Jack 4.4mm connector
  • A balanced Jack 2.5mm connector
  • 3 pairs of silicone eartips
  • 3 pairs of foam eartips
  • A storage pouch
Product typeIn-ear monitors (IEM)
Drivers1* Sonion EST
2* Knowles DWFK 31785
1* Sonion 28UAP
2* IMPACT2 (10mm composite DD)
Filter4-way passive crossover
Sensitivity99dB @ 1kHz (±1dB)
Impedance20Ω
Frequency response20Hz-40kHz
Cable conductors materialSilver plated 6N OCC copper
Cable conductors section0.326mm² (22AWG)
Cable length1.2m
Earphone connectorsCIEM 2 pins 0.78mm
Cable connectorsCIEM 2 pins 0.78mm
Interchangeable connector : Jack 3.5mm, Jack 2.5mm, Jack 4.4mm
Connectors contacts platingGold
Package1* Pair of Thieaudio Monarch MKIII earphones
1* Detachable cable with interchangeable connectors
1* Jack 3.5mm connector
1* Balanced Jack 4.4mm connector
1* Balanced Jack 2.5mm connector
3* Pairs of silicone eartips
3* Pairs of foam eartips
1* Storage and transport pouch
Impedance (Ω)20
Efficiency / Sensitivity (dB)99.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 2.5mm
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
2 reviews
Je viens d'acquérir, il y a quelques petites semaines l’IEM de chez THIEAUDIO MONARK MKIII sur ce site.
Service très rapide (comme d’habitude) d’Audiophonics. Parfait.
Actuellement environ 100 heures d'utilisation en Symétrique 4,4 mm tant sur Walkman SONY NW-WM1AM2 (Modèle Japonais non plafonné), Shanling M9 et Ampli Casque /Dac Sony TA-ZH1ES et parfois Sony PHA2a.
J’utilises le cable fourni, de bonne qualité avec sa prise modulable en 4,4 mm, (celle ci d'ailleurs, de par son adaptateur se détache assez souvent, et constaté par d'autres utilisateurs sur des forums) mais aussi un cable de chez LunaShop et Ears Tips / embouts silicone d’origine, même si je viens depuis plusieurs jours de mettre des SpinFit W1, car j’ai une petite préférence personnelle pour ceux ci, mais dans tout les cas, je trouve un bon confort pour de longues sessions, malgré la taille des coques des MONARK MKIII et j’ai des oreilles normales.
Bref, de très bonnes associations, rien a dire, ça rend très bien et j'en suis vraiment pleinement satisfait y compris dans des styles musicaux divers).
(Pour le son, on trouve quelques avis et tests fiables sur cet IEM qui permettent de savoir a quoi on a affaire et de comparaisons avec d'autres produits équivalents)
Je préciserai que j'écoutes beaucoup d'électronique (Tangerine Dream, Jarre, Carlos, Tomita, Synergy, Steve Roach, Schulze, Pink Floyd etc etc... mais aussi un peu de voix variées : Maria Mena, Assala Nasri, Myrkur, Farmer, Krall, Rondstadt..., musiques de films..., un peu de classique : clavecin et musique d'orgue de différentes périodes et artistes.
THIEAUDIO Monark MKIII : en bref :
Pas d’effet WOW ! a la première écoute, je dirai ici que ce n’est pas mon seul IEM, en effet j’utilise aussi les SENNHEISER IE 900, SONY IER-M9, SHANLING ME800, AFUL Performer 8 et… THIEAUDIO Oracle MKII.
Design simple de base, (je préfères la déco de l’Oracle MKII) mais personnalisable sur le site du fabricant.
Sans rentrer dans les détails, car chacun aura surement un avis différent, en fonction de ses gouts, sources, fichiers musicaux, et que les avis ou reviews du web sont globalement très bons.
Il demande moins de puissance que l’Oracle MKII (surement une histoire de Sensibilité et d’impédance en liaison avec mon matériel d’écoute.
Package typique Thieaudio : vraiment le minimum, mais ça fait le Taf. Je n’ai pas essayer les Embouts en mousse.
J’apprécie beaucoup le son donc son rendu, avec MES oreilles (Pas de Sibilance ou d’aigu agressif, belles basses profondes et organiques si la piste le réclame, (même si l’Oracle MKII est vraiment très agréable aussi), en fait cela pourrait être une fin de jeu en soi.
Je n’ai pas ressenti spécialement qu’il est eu besoin de rodage, même si j’ai eu vraiment l’impression d’un quelque chose de mieux (équilibre ?) après 30/35 d’heures.
(En me basant sur quelques morceaux de musique différents que je connais bien et que j’ai réécoutés plusieurs fois depuis le début pour en tester les possibles évolutions.
j’ai également fait l’essai du changement de cable d’origine par celui d’Effect Audio l’Eros S qui semblent apporter un peu plus de subtilité dans les détails.
Quoi qu’il en soit, je suis pleinement satisfait de ce MONARK MKIII, au point qu’actuellement, il fait de l’ombre aux autres.
(Cela ne remet nullement en doute les qualités de ceux ci, juste une approche différente ou l’effet nouveau jouet).
Une belle découverte et choix que ce MONARK MKIII et qu’ Audiophonics nous permet d’obtenir sans passer par la case import de Chine.
Je ne peux que recommander
Et je n'en oublies surtout pas la qualité des fichiers, qui reste primordiale sur une bonne source pour en extraire la quintessence.
This review has been posted for THIEAUDIO MONARCH MKIII In-Ear Monitor IEM Dynamic Electrostatic 20 Ohm 99dB 20Hz-40kHz
- Service très rapide (comme d’habitude) d’Audiophonics. Parfait.
- Actuellement environ 100 heures d'utilisation en Symétrique 4,4 mm tant sur Walkman SONY NW-WM1AM2 (Modèle Japonais non plafonné), Shanling M9 et Ampli Casque /Dac Sony TA-ZH1ES et parfois Sony PHA2a.
- J’utilises le cable fourni, de bonne qualité avec sa prise modulable en 4,4 mm, (celle ci d'ailleurs, de par son adaptateur se détache assez souvent, et constaté par d'autres utilisateurs sur des forums) mais aussi un cable de chez LunaShop et Ears Tips / embouts silicone d’origine, même si je viens depuis plusieurs jours de mettre des SpinFit W1, car j’ai une petite préférence personnelle pour ceux ci, mais dans tout les cas, je trouve un bon confort pour de longues sessions, malgré la taille des coques des MONARK MKIII et j’ai des oreilles normales.
- Bref, de très bonnes associations, rien a dire, ça rend très bien et j'en suis vraiment pleinement satisfait y compris dans des styles musicaux divers).
- Je préciserai que j'écoutes beaucoup d'électronique (Tangerine Dream, Jarre, Carlos, Tomita, Synergy, Steve Roach, Schulze, Pink Floyd etc etc... mais aussi un peu de voix variées : Maria Mena, Assala Nasri, Myrkur, Farmer, Krall, Rondstadt..., musiques de films..., un peu de classique : clavecin et musique d'orgue de différentes périodes et artistes.
- Pas d’effet WOW ! a la première écoute, je dirai ici que ce n’est pas mon seul IEM, en effet j’utilise aussi les SENNHEISER IE 900, SONY IER-M9, SHANLING ME800, AFUL Performer 8 et… THIEAUDIO Oracle MKII.
- Design simple de base, (je préfères la déco de l’Oracle MKII) mais personnalisable sur le site du fabricant.
- Sans rentrer dans les détails, car chacun aura surement un avis différent, en fonction de ses gouts, sources, fichiers musicaux, et que les avis ou reviews du web sont globalement très bons.
- Il demande moins de puissance que l’Oracle MKII (surement une histoire de Sensibilité et d’impédance en liaison avec mon matériel d’écoute.
- Package typique Thieaudio : vraiment le minimum, mais ça fait le Taf. Je n’ai pas essayer les Embouts en mousse.
- J’apprécie beaucoup le son donc son rendu, avec MES oreilles (Pas de Sibilance ou d’aigu agressif, belles basses profondes et organiques si la piste le réclame, (même si l’Oracle MKII est vraiment très agréable aussi), en fait cela pourrait être une fin de jeu en soi.
- Je n’ai pas ressenti spécialement qu’il est eu besoin de rodage, même si j’ai eu vraiment l’impression d’un quelque chose de mieux (équilibre ?) après 30/35 d’heures.
- j’ai également fait l’essai du changement de cable d’origine par celui d’Effect Audio l’Eros S qui semblent apporter un peu plus de subtilité dans les détails.
- Quoi qu’il en soit, je suis pleinement satisfait de ce MONARK MKIII, au point qu’actuellement, il fait de l’ombre aux autres.
With updated and optimised drivers and adjustments, as well as significantly improved ergonomics, Thieaudio Monarch MKIII in-ear earphones deliver...
