By buying this product you get 139 loyalty points
In-Ear Monitors IEM Hybrid 11 Ohm 95dB 20Hz-40kHz
The Thieaudio Prestige in-ear monitors feature a unique hybrid design. Each earphone integrates no less than 9 speakers to propel your listening experience into a whole new world. The Thieaudio Prestige are equipped with 4 electrostatic tweeters for high frequencies, 4 Balanced Armature drivers for midrange and low frequencies as well as a dynamic driver for bass, thus reproducing the entire audio spectrum with incredible ease.
To operate such a complex array, the Thieaudio Prestige incorporates a 5-way passive crossover network, assigning each speaker a range of the frequency band to reproduce while reducing overall harmonic distortion. This passive crossover consists of 11 independent passive components, carefully designed to provide a natural sound signature and a perfect balance of timbres.
The Prestige has been acoustically designed to deliver the most transparent and faithful sound possible, without coloration. The midrange remains neutral and natural. The infrabass is slightly forward below 250Hz to offer a powerful and deep impact, without compromising the overall sound signature. But the real strength of the Thieaudio Prestige is undoubtedly its extension of the highs and very high frequencies, revealing an airy sound, without aggressiveness, but yet of great precision.
Each Thieaudio Prestique earphone is handcrafted by the brand's engineers. The shell is made of 3D printed medical grade resin, a durable and perfectly hypoallergenic material. In addition, their shape is optimized to fit the contours of the ear perfectly and thus ensure optimal comfort.
The Thieaudio Prestige comes with a detachable cable for excellent electrical conductivity. It uses silver-plated OCC 6N copper conductors within a Litz wire structure. It also comes with three connectors in single-ended Jack 3.5mm as well as balanced Jack 4.4mm and Jack 2.5mm. It adapts to the vast majority of source devices. The connection to the headphones is done via a standard 0.78mm 2 pins CIEM connector.
Product type | In-ear monitors (IEM) |
Drivers | 4* Electrostatic drivers 4* Balanced Armature drivers 1* Dynamic driver |
Impedance | 11Ω |
Sensitivity | 95dB @ 1kHz |
Frequency response | 20Hz - 40kHz |
Cable conductors material | 6N OCC Copper |
Cable length (switchable) | 1.2m |
Cable conductors section | 0.326mm² (22AWG) |
Package | Thieaudio Prestige IEM 1* Cable 1.2m 3* Pairs of silicone eartips 3* Pairs of foam eartips 1* Carrying pouch |
Color | Black |
Impedance (Ω) | 11 |
Efficiency / Sensitivity (dB) | 95.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 40000 |
Wireless | No |
Cable termination | Jack 4.4mm |
Cable termination | Jack 3.5mm |
Cable termination | Jack 2.5mm |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
