TRUTHEAR GATE In-Ear Monitor White
New
Truthear's Gate earphones offer unbeatable value for money. They feature a dynamic driver with a carbon and liquid crystal polymer diaphragm and polyurethane suspension to deliver textured bass and extended highs. Despite their low price, these earphones comply with HRTF specifications and deliver a balanced sound with a natural timbre.
Reference : 20547
20,90 €tax incl.
17,42 € tax excl.
Shipping date: 24-04-2025.
Truthear Gate Dynamic In-Ear Monitor IEM Ø10mm 28Ω 122dB 10Hz-45kHz White
Truthear Gate : Front view
Truthear
's Gate earphones
Truthear Gate: Ø10mm dynamic driver
Truthear's Gate is based on a Ø10mm dynamic driver with a composite carbon and liquid crystal polymer (LCP) cone. The addition of carbon to traditional LCP diaphragms results in greater rigidity, improving the driver's sensitivity and high-frequency response. The polyurethane (PU) suspension that accompanies the new diaphragm ensures deep, textured bass.
Truthear Gate : Driver composition
Finally, the driver is accompanied by a large, ultra-thin CCAW voice coil, ensuring good frequency response without hindering the suspension system.
Truthear Gate : CCAW voice coil
Truthear Gate: Well-balanced sound profile
The use of this new diaphragm coupled with an optimised acoustic structure results in minimal linear distortion and an extension in the reproduction of high frequencies. This amplitude of the frequency range meets the requirements of the HRTF characteristics and offers a balanced sound reproduction with measured bass.
Truthear Gate : Frequency response curve
Furthermore, the Gate exhibits an exceptionally low level of non-linear distortion, with less than 0.2% over the majority of the frequency band. This results in a very clean noise floor, allowing you to apply the equalisation of your choice without any negative effect on the final sound.
Truthear Gate : Non-linear distortion curve
Truthear Gate: Wearing comfort
With these earphones, Truthear has not only focused on the quality of sound reproduction, but also on wearing comfort. The Gate has a composite body made from PC+ABS, providing a good compromise between lightness and strength. Furthermore, the shape of the earphones has been reworked, with smaller tips to reduce the discomfort that can sometimes be experienced with in-ear monitors.
Truthear Gate : earphones on their pouch
Truthear Gate : Cable with microphone
Truthear Gate: OFC copper cable
The Gate comes with a 3.5mm jack to 0.78mm 2-pin OFC copper cable for optimum signal transmission. Furthermore, the cable is fitted with a microphone and volume control.
Product typeIn-ear monitors (IEM)
Driver1x Dynamic driver
Driver diaphragmØ10mm in carbon and liquid crystal polymer (LCP)
Impedance28Ω ±15% @ 1kHz
Sensitivity122dB @ 1kHz
Total harmonic distortion (THD)≤1% @ 1KHz (94dB)
Frequency response10Hz-45kHz
CableDetachable
Earphone connectorCIEM 0.78mm 2 pins
Cable terminationJack 3.5mm
Cable materialOFC Copper
ColorWhite
Package1x Truthear Gate
1x 3.5mm jack to CIEM 0.78mm 2 pin cable with microphone
1x Carrying pouch
7x Pairs of ear tips
ColorWhite
Impedance (Ω)28
Efficiency / Sensitivity (dB)122.0
WirelessNo
Phone call featureYes
Noise reductionNo
TRUTHEAR GATE Dynamic In-Ear Monitor IEM Ø10mm 28 Ohm 122dB 10Hz-45kHz White
Truthear's Gate earphones offer unbeatable value for money. They feature a dynamic driver with a carbon and liquid crystal polymer diaphragm...
