TRUTHEAR C CRINACLE ZERO In-Ear Monitor
With the Zero, Truthear has teamed up with Crinacle, renowned for its expertise in IEM, to offer in-ear earphones based on two dynamic drivers with liquid-crystal polymer diaphragms to deliver rigorously accurate sound reproduction according to HRTF characteristics.
Reference : 20431
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 24-04-2025.
Truthear x Crinacle Zero Dynamic In-Ear Monitor IEM Ø10mm/Ø7.8mm 10Ω 117.5dB 20Hz-39500Hz
Truthear Zero : Front view
With the Zero, Truthear has teamed up with Crinacle, renowned for its expertise in IEM, to offein-ear earphones based on two dynamic drivers with liquid-crystal polymer diaphragms to deliver rigorously accurate sound reproduction according to HRTF characteristics.
Truthear Zero : Dynamic dual drivers
The Zero features a dual-driver dynamic configuration, 10mm and 7.8mm in diameter respectively, to deliver a smooth, detailed sound thanks to a sophisticated magnetic circuit structure combined with liquid crystal polymer (LCP) diaphragms and flexible polyurethane suspensions.
The 7.8mm dynamic driver responsible for midrange and high frequencies uses an ultra-fine CCAW voice coil, aiming to make the driver as light as possible. The result is a greater sensitivity to high frequencies, offering a clear and delicate rendering. On the other hand, the 10mm dynamic driver is responsible of low frequencies, and uses a weighted voice coil to reduce the resonance frequency for a clear delimitation of each driver's role in the frequency band.
Truthear Zero: Back view
Truthear Zero: Front view
Truthear Zero : DLP 3D printing design
The structure of the Zero's acoustic nozzles benefits from DLP (Digital Light Processing) 3D printing, enabling an assembly finesse that would otherwise be impossible. In this way, Truthear was able to precisely design its internal cavity and acoustic nozzles to get the best out of both drivers, efficiently guiding the waves produced by them.
Truthear Zero : HRTF sound profile
The Zero's low-frequency gain and HRTF-compliant treble response give them a profile comparable to professional monitoring earphones, while being slightly less cold and rigid in their final rendering.
Furthermore, the Zero's relatively neutral sound to the ear has been carefully engineered to avoid phase distortion, a recurrent problem in earphones with multiple drivers and the cause of unnatural sound reproduction.
Truthear Zero: Front view with cable
Truthear Zero: earphones and cable
Truthear Zero : High-quality cable
The Zero comes with a 3.5mm to 0.78mm 2-pin jack cable made of 4 strands of silver-plated copper, guaranteeing high-quality signal transmission without external interference.
Test of Truthear Zero by Audio Science Review
" What on earth are you doing reading the rest of this review? Go and buy one of these! I don't care if you don't listen to IEMs normally. You want this IEM so you know what correct tonality is, when you listen with other transducers such as headphones and speakers. Think of it as the tuning fork that a musician uses! This IEM needs to be in your arsenal. "
Product typeIn-ear monitors (IEM)
Speakers2x Dynamic drivers
Dynamic driver diaphragmØ10mm liquid crystal polymer (LCP)
Ø7.8mm liquid crystal polymer (LCP)
Impedance10Ω ±15% @ 1kHz
Sensitivity117.5dB @ 1kHz
Total harmonic distortion (THD)≤ 1% @ 1kHz
Frequency response20Hz-39500Hz
CableDetachable
Earphone connectors2 pins 0.78mm
Cable terminationJack 3.5mm
Cable materialsSilver-plated copper
ColorBlue
Package1x Truthear Zero
1x 3.5mm jack to 0.78mm 2-pin cable
7x Pairs of ear tips
ColorBlue
Impedance (Ω)10
Efficiency / Sensitivity (dB)117.5
Lowest frequency (Hz)20
Highest frequency (Hz)39500
WirelessNo
Phone call featureNo
Noise reductionNo
TRUTHEAR X CRINACLE ZERO Dynamic In-Ear Monitor IEM Ø10mm/Ø7.8mm 10 Ohm 117.5dB 20Hz-39500Hz
With the Zero, Truthear has teamed up with Crinacle, renowned for its expertise in IEM, to offer in-ear earphones based on two dynamic drivers with...
