TRUTHEAR X CRINACLE ZERO:RED In-Ear Monitor
With the Zero RED, Truthear has once again teamed up with Crinacle, renowned for its expertise in IEM, to offer a new version of the fruit of their previous collaboration. These in-ear earphones retain the dynamic dual-driver structure of their predecessors, but improve on it to offer an even lower level of distortion. Furthermore, the frequency response curve is also slightly different, offering punchier bass while preserving the characteristic neutrality of the previous model.
Reference : 20433
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 06-10-2026.
Truthear x Crinacle Zero RED Dynamic In-Ear Monitor IEM Ø10mm/Ø7.8mm 17.5Ω 117.5dB 20Hz-40500Hz
Truthear Zero RED : Front view
With the Zero RED, Truthear has once again teamed up with Crinacle, renowned for its expertise in IEM, to offer a new version of the fruit of their previous collaboration. These in-ear monitors retain the dynamic dual-driver structure of their predecessors, but improve on it to offer an even lower level of distortion. Furthermore, the frequency response curve is also slightly different, offering punchier bass while preserving the characteristic neutrality of the previous model.
Truthear Zero RED: Dual drivers
The Zero REDs feature a dual dynamic driver configuration, 10mm and 7.8mm in diameter respectively, to deliver a smooth, detailed sound thanks to a sophisticated magnetic circuit structure combined with liquid crystal polymer (LCP) diaphragms and flexible polyurethane suspensions.
The 7.8mm dynamic driver responsible for midrange and high frequencies uses an ultra-fine CCAW voice coil, with the aim of making the driver as light as possible. The result is greater sensitivity to high frequencies, offering a clear, delicate soundstage. Conversely, the 10mm dynamic driver is responsible for low frequencies, and uses a weighted voice coil to reduce the resonant frequency for clear delineation of each driver's role in the frequency band.
Although the Zero RED drivers are similar to those of the Zero, the internal structure has been completely redesigned to offer better measurements while maintaining an equivalent frequency response. Furthermore, the diaphragm structure has been adjusted to deliver slightly more bass and even lower non-linear distortion.
Truthear Zero RED : drivers
Truthear Zero RED: internal composition
Truthear Zero RED: DLP 3D printing design
The acoustic nozzle structure of the Zero REDs benefits from a DLP (Digital Light Processing) 3D printing design, enabling an otherwise impossible level of assembly finesse to be achieved. In this way, Truthear was able to precisely design its internal cavity and acoustic nozzles to get the best out of both drivers, efficiently guiding the waves produced by them.
Truthear Zero RED: An updated sound profile
Building on the Zero's excellent measurements, the RED version further optimizes the latter to reduce non-linear distortion at a higher sound pressure level of 94dB. The frequency response target curve is similar to that of its predecessors, but adopts the CRINACLE IEF_Neutral target curve for the frequency band above 1000Hz, offering a rendering that conforms to HRTF characteristics while being warm and natural.
Truthear Zero RED : Frequency response curve
Furthermore, the Zero REDs are relatively neutral to the ear, and special care has been taken to avoid phase distortion, a recurrent problem in earphones with multiple drivers and responsible for unnatural sound reproduction.
Truthear Zero RED: Quality cable
The Zero REDs come with a 1.20m Jack 3.5mm to CIEM 0.78mm 2-pin jack cable with 4 strands of silver-plated copper, guaranteeing high-quality signal transmission without external interference.
Truthear Zero RED : Supplied cable
Review of Truthear Zero RED by Audio Science Review
"Folks, we have another reference class IEM for hardly any money. Yes, there is a bit different tuning but whether that is better or not, is hard to determine given the uncertainty in measurements, and listening preference at granular level. I am happy with either but like the lower distortion in RED. I could not reduce distortion the original Zero. So the RED gets my vote as to the better of the two by small margin.
It is my pleasure to add Truthear x Crinacle Zero RED to my recommended list. Skip a lunch or two out and put this in your arsenal even if you are not a regular IEM user. "
Product typeIn-ear monitors (IEM)
Drivers2x Dynamic drivers
Dynamic driver diaphragmØ10mm in liquid crystal polymer (LCP)
Ø7.8mm in liquid crystal polymer (LCP)
Impedance17.5Ω ±15% @ 1kHz
Sensibility117.5dB @ 1kHz
Total harmonic distortion (THD)≤ 1% @ 1kHz
Frequency response20Hz-40500Hz
CableDetachable
Earphone connectorsCIEM 0.78mm 2 pins
Cable terminationJack 3.5mm
Cable materialsSilver-plated copper
ColorRed
Package1x Truthear Zero RED
1x 3.5mm jack to CIEM 0.78mm 2-pin cable
7x Pairs of ear tips
1x 10Ω impedance adapter
ColorRed
Impedance (Ω)17.5
Efficiency / Sensitivity (dB)117.5
Lowest frequency (Hz)20
Highest frequency (Hz)40500
WirelessNo
Phone call featureNo
Noise reductionNo
2 reviews
D'une remarquable qualité
Excellents écouteurs, tant par leur qualité de construction que par leur son. Les embouts en mousse fournis avec isolent également bien.
This review has been posted for TRUTHEAR X CRINACLE ZERO:RED In-Ear Monitor IEM Ø10mm/Ø7.8mm 17.5 Ohm 117.5dB 20Hz-40500Hz
Very happy. These iem's are a steal!
For this very reasonable price, finding an equally good sounding iem will be a serious challenge. This time you can trust those rave reviews. The Zero:Red is extremely neutral, detailed and free of distortion. It deserves to be partnered with your best DAC/headphone amp. They are also comfortable. On the other hand, for those people with small ear canals, keep in mind that the nozzle size is bigger than usual: 6 mm.
Initially there was a supply problem at the manufacturer (I suppose) due to the high demand, but those fantastic people at Audiophonics kept me informed at all times. A shining example of how to do business!
With the Zero RED, Truthear has once again teamed up with Crinacle, renowned for its expertise in IEM, to offer a new version of the fruit of their...
