xDuoo Ep1 intra-auricular audiophiles
![Xduoo ep1 Xduoo ep1](https://www.audiophonics.fr/img/cms/thumbs%202_19.jpg)
xDuoo has designed the EP-1 in-ear for a single purpose: Bring the best isolation and reproductive quality at a democratic price.
Agile in any situation
![Xduoo ep1 Xduoo ep1](https://www.audiophonics.fr/img/cms/eclat%C3%A9%20Ep1.jpg)
Produced in an extruded aluminum casing, the xDuoo EP1 produces a high readability sound with 10mm diaphragm professsionel diaphragms offering increased capacity in the bass.
Attention for every detail![xduoo EP1 xduoo EP1](https://www.audiophonics.fr/img/cms/datasheet%20c%C3%A2bles.jpg)
This in-ear headset features an "anti-twist" 5-way, 32-strand OFC copper cable. Due to its struture this cable does not knot in a pocket or in a bag. Its 16 ohm impedance makes it compatible with a wide range of smartphones and especially with iPad and iPhone tablets.
Connectivity and listening comfort
![xduoo EP1 xduoo EP1](https://www.audiophonics.fr/img/cms/medley%20connectique%20emboute_1.jpg)
The Xduoo EP1 features two classic memory foam tips and three silicone earpieces that perfectly fit your ears for optimal isolation from outside noise. Its gold-plated-gold connector provides high-fidelity audio with a 108dB output for ultra-dynamic listening.
![xduoo EP1 xduoo EP1](http://www.audiophonics.com/img/cms/thumbs%204_26.jpg)
Technical featuresc
Specifications |
Type | Intra Auricular |
Headphones | Aluminum factory CNC |
Membranes | Low distortion 10mm |
Permissible power | 10mW |
Pressure level | 108dB / mW |
Bandwidth | 10Hz - 20kHz |
Nominal impedance | 16Ω over 1kHz |
Weight of each earpiece | 4g |
Cable length | 1.2m |
Miscellaneous |
Total weight | 16g |
