1MII B08S Amplifier 2.1 Class D Bluetooth 5.0 Receiver aptX HD QCC3034 2x50W / 4 Ohm
1MII B08S Amplifier 2.1 Class D Bluetooth 5.0 Receiver aptX HD QCC3034 2x100W
The 1Mii B08s is a Bluetooth receiver with integrated amplifier that is both affordable and powerful. Incorporating a Qualcomm QCC3034 chip, it features Bluetooth 5.0 reception with support for the high-resolution transmission codecs aptX, aptX LL and aptX HD.
Reference : 15113
99,00 €tax incl.
82,50 € tax excl.
1Mii B08s
1Mii B08s Amplificateur 2.1 Class D Bluetooth 5.0 aptX HD QCC3034 2x100W
The 1Mii B08s is a Bluetooth receiver with integrated amplifier that is both affordable and powerful. Incorporating a Qualcomm QCC3034 chip, it features Bluetooth 5.0 reception with support for the high-resolution transmission codecs aptX, aptX LL and aptX HD. Equipped with two antennas, it allows long-distance transmission, up to 50m without obstacles. A 3.5mm jack input is also available.
Its amplification stage allows it to develop a power of 2x50W, ideal to accompany small passive bookshelf loudspeakers.
On the output side, there are of course speaker terminals, but also a Subwoofer output on RCA.
The front panel of the device has three buttons, allowing you to adjust the volume level, but also to adjust the bass and treble levels.
Product typeBluetooth amplifier
InputsBluetooth 5.0
1x Jack 3.5mm
1x Stereo RCA
1x Optical Toslink
Outputs1x Speaker terminals
1x Subwoofer RCA
Bluetooth version5.0
Supported Bluetooth profilesA2DP
AVRCP
Supported Bluetooth codecsSBC
aptX
aptX LL
aptX HD
Max transmission distanceWithout obstacles : 30m
Power output2x 50W / 4 Ohm
Operating temperature range-10°C / +45°C
Supply voltage24VDC 4A
Dimensions136 x 101 x 45mm
Weight230g
colorBlack
Package1x 1Mii B08s
1x Power supply 24V 4A
InputJack 3.5mm
OutputSubwoofer
OutputSpeaker terminal
DAC / ADC ChipNC
Max sampling rateNC
Channel2.1
Amplifier chipN/A
Power (W)50.0
Top
Petit ampli qui bouge très bien une paire de cabasse, bonne connexion et bonne puissance, le son est pas mal du tout...
This review has been posted for 1MII B08S Amplifier 2.1 Class D Bluetooth 5.0 Receiver aptX HD QCC3034 2x50W / 4 Ohm
The 1Mii B08s is a Bluetooth receiver with integrated amplifier that is both affordable and powerful. Incorporating a Qualcomm QCC3034 chip, it...
