Class AB 2x50W 4 Ohm
This AMP40 is an efficient and inexpensive solution for enjoying a good quality Class AB amplification system. Its amplification stage is based on MOSFETs and is capable of developing no less than 2x50W at 4 Ohm, allowing it to accompany many speakers without flickering. Its careful design allows it to limit distortion and noise at the output for a precise and transparent reproduction, while developing a beautiful dynamic and a wide sound image.
On the connector side, the AMP40 is simple and efficient. There is a Stereo RCA input to connect your source to the amplifier and speaker terminals with gold-plated contacts at the output. The unit also has a 3.5mm jack jack for quality listening to headphones.
All components are integrated in a simple and elegant black aluminium housing. Its compactness allows it to be integrated without any problems, even in installations where the available space is limited.
1 | Volume button |
2 | Right speaker output |
3 | Left speaker output |
4 | ON/OFF Switch |
5 | Power supply connector 12-14V DC (power supply sold separately) |
6 | Headphone output |
7 | Stereo RCA Input |
Product type | Integrated amplifier |
Class | AB |
Output power | 2x50W @ 4 Ohm |
Distortion | 0.08% |
Frequency response | 6Hz - 80kHz (-3dB) |
Input | 1x Stereo RCA |
Output | Speaker terminals 1x Jack 3.5mm (headphone output) |
Power supply connector | Jack DC 5.5/2.5mm (12-14V) |
Dimensions | 120 x 155 x 49mm |
Weight | 500g |
Material | Aluminium |
Color | Black |
Power supply sold separately |
